Solar Advice For a Novice (2 Viewers)
BravoTwoZero
25
4
Herts
Hello Everyone,
My wife and I bought our first motorhome in September and have been on a steep learning curve ever since ! We took the plunge and got an new Elddis Autoquest 115.
Our leisure battery is being replaced under warranty and I wondered whether a solar panel would be a good investment. The Elddis is parked in a secure compound 10 minutes from home with no ehu. We plan to stay mainly at Caravan Club sites but also do some wild camping in the highlands. The main reason though for thinking solar is for battery care when stored.
I would be very grateful for any advice.
David
Kool Kroozer
1,361
2,228
Cannock Staffordshire
Low Profile Hobby Premium
Always learning
Yes solar and a battery master is the way to go, an if your a bit of a DIYer have a go at fitting them yourself - there is nothing hard or complicated about it at all, i have just fit x2 140w panels and cant fathem why people pay dealerships to supply and fit a 100w panel with solar charger £500 - my quote for x2 140 panels with a solar charger was £700, I paid £285 for everything (apart from sikaflex which was £10) and fit them myself in a couple of hours - the hardest part i found was figuring out the cable run to the leisure batteries. gives you a sense of satisfaction and knowing whats been done.
18,032
48,111
As above, solar on its own won't normally charge the vehicle battery. For that you need a battery master.
Go for at least 100W of solar, twice that if you can would be my suggestion. You can then begin to think about the wonderful world of inverters!
However, you can get little panels which just top up the vehicle battery but ideally for these you need a cigar lighter socket which is live with the ignition turned off, which are rare and some wiring will be required instead.
BravoTwoZero
BravoTwoZero
25
4
Herts
Many thanks for the replies. I would struggle to install myself so will get some quotes.
19,365
30,303
You can get a solar regulator that had two outputs, the main one goes to the habitation batteries and the other sends a small current to the starter battery.
Make sure you get a MPPT regulator, they are more expensive but will give you more amps from your panel especially when the weather is a bit iffy.
Dont know how good they are but you can get little solar panels that sit on your dash and trickle charge the battery while sitting in the street. This plugs into the fag lighter socket. Now they may be crap i dont know as the alarm may take more juice out than the panel puts in but worth a look just in case.
DanielFord
3,020
3,086
Unless you flip the wiring behind the dash, the cig lighter is disabled with no ignition on the Ducato, so that won't work.
That part i was not to sure about. I have one in the boot on my car that is not on the ignition. My car uses a lot of juice on the alarm and can sit unused for two weeks. Thats enough to drain my battery. Not 100% but down to 12v what will not start the car. Kind if thinking this may be my answer as well.
DanielFord
3,020
3,086
We have a car that sits unused for months at a time, the solution is simple, and I think it cost us £5.25 from halfrauds. A battery isolator terminal, when you leave the car, pop the bonnet and switch off the battery. The battery will still be good to go months later when you return :D
Modern cars drain so much power even when they are in 'off' mode!
43,331
49,482
Your insurers will love you....any excuse not to pay out.
Isolating the battery also isolates the alarm and not all stolen cars are driven away.
DanielFord
3,020
3,086
I'd just love to see it if it happened, window smashed, hot wire done......
"Oi! Kevin, it ain't startin'"
"Fak it, let's nick a soobaarooo"
LOL!
BravoTwoZero
BravoTwoZero
25
4
Herts
Thanks again everyone. Just got a quote for a panel from a very local servicing company, £599 for 100w and £699 for 120w both including vat. Does this sound reasonable.
8,490
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
1,023
5,392
Gloucester
Self-converted Van
Since 2014
I would get a quote from @Vanbitz, with the funsters discount, we paid about that amount for our solar panel, battery master, mppt controller and second leisure battery, all fitted and including a free night at their campsite. Plus you have the reassurance of getting the work done by a highly respected company:)
DanielFord
3,020
3,086
As it happens I have my paperwork from VanBitz handy, 150w solar fully fitted with battery master and MPPT £699 - 10% funster discount!
I drive an 2002 car and not worth claiming on and i see no mention of having to have the alarm set or my policy would be void.
10,117
18,383
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
ours loses the radio code if we do that
Most do mate. They have a constant live wire for the sake if the stereos memory. Clock, Channels etc. They tend to be a yellow wire on after market stereos. This is where i go if i need a live for something.
