SOG??? (5 Viewers)
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Done a search, but cant find any discussion on this. Anyone got one??? Expensive, but it seems like a great idea.
17,637
43,375
a huge amount of money for a computer fan, a switch and some flexi hose. then all it does is pump the smell of untreated shit outside for everyone else to smell. pretty antisocial on a campsite when your neighbours are having their alfresco breakfast as you take a dump:Sad:
Nov 4, 2011
5,944
39,102
Uk
Also got a charcoal filter, so not much smell outside when in use.
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Great, then on that recommendation, I will buy one!! If I have to put up with everyone's stinking fish barbecues in the evening, mixed in with tons of disgustingly anti-social garlic, farmer Brown's cows in the next field, (And Farmer Browns s**t spraying habits,) the waft from the outside elsen that someone forgot to flush, then they can put up with my morning dump, (which most of them will never smell, as their still in bed, pi**ed from last nights very loud 2AM party). :thumb:
23,836
72,558
HAd one in all our vans.. Would not really like to have a MH without one to be honest
Armytwowheels
6,476
14,883
Market Harborough
Carthago S Plus - Iveco
Since 2011
Just elbowing Tootles a side here, soz Toots.
We have a sog on our new (to us) van. Where should I be looking to check if we have a charcoal filter?
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Its in the thingie on the outside of the door..........:thumb:
Armytwowheels
6,476
14,883
Market Harborough
Since 2011
Ok, I will have a look tomorrow and see if there is a filter there. Presumably, when someone pitched next to you on a site complains about the smell, that is the indicator that you need to change the filter?:ROFLMAO:
Feb 24, 2013
13,090
101,512
Bolsover, Derbyshire
Hymer S800
not long enough
Had SOG on last MH, never aware of any smell on outside, but fan only runs when blade is open
My big anti was driving with cassette nearly full on winding roads I ended up with poo streaks down side of MH, not nice at all
After that always emptied before leaving site or put cap on vent pipe before moving when I remembered
Some have vent to roof so no problem for them
Armytwowheels
6,476
14,883
Market Harborough
Since 2011
[HI]My big anti was driving with cassette nearly full on winding roads I ended up with poo streaks down side of MH, not nice at all[/HI]
Ewwww:Eeek: that can't be right, surely?
Feb 24, 2013
13,090
101,512
Hymer S800
not long enough
Not sure if mine was a home fitted or badly fitted version, but if smelly air can get out what stops liquid following, on most that I have seen the air outlet is on the door to the cassette so dangerously close to contents level
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Hmmmmmmmm........Maybe someone you ran over??????? :Eeek:
ShiftZZ
21,383
84,603
Dark Side of the Moon
There is an easier solution...
a) Wrap up the pooh in cling film and freeze it, dump it at the next available bin.
b) Drink a spoonful of Brute aftershave, that will nullify the pong and if you have an accident then "Splash it all over".
:thumb:
2,356
10,238
dumping in a confined space is very anti social..:thumbdown::youbetcha:
Ban #2s ........ use site toilet.. or if at a meet, use the neighbours van.. show interest and pretend to check out their facilities.. then do a crafty dump ..:ROFLMAO:
Ridgeway
3,666
6,180
Lausanne
NiBi Arto 85E
Installed 2 now, one on each van and wouldn't be without one.
There is a DIY thread on here where someone made their own and nicely done, if you're capable enough then go for it.
If like me time and a neat install is important then you'll be pleased with the ÂŁ100 or so for a well put together kit of parts and availability or spare parts.
As for the smell, if you change the carbon filter once p/a then it's really no issue.
18,038
48,155
Our SOG works fine but we also add a capful of bio washing liquid after every empty. This makes the contents sweet smelling when it comes to the next emptying.
11,933
9,097
Save over ÂŁ100 and do a DIY SOG :thumb:Cost me nothing other than a couple of mugs of coffee --look for my Diy SOG thread for details :thumb:
terry
11,933
9,097
terry
Just to clarify it's made up from a BATH OVERFLOW PIPE WHICH NEEDS 2 ENDS -ONE GOES INTO THE VENT VALVE/remove/ IN THE CASSETTE --the other is set into the back of the door -a surface mount light/socket box and front blanking plate that holds the charcoal filter from a cooker hood -31/2 ins comp fan goes in between door and light box -bit of wire and the micro switch that turns fan on when blade is opened
2,356
10,238
Here is another idea..
provided the cassette compartment is air tight there is no need for a vent pipe..the fan can be mounted on the toilet door and will create negative pressure in the compartment when running .. a modified cap on the cassette allows the air to flow through the toilet when the shutter is opened..
Blog with piccies.. http://www.dreampod.net/boroma/toilet_vent.html
I like it .. simple
Simon_H
Benfleet, Essex
Azalai
SOG fans work very well and I wouldn't have a van without one. However it does make you more disciplined when it comes to emptying the cassette. A certain amount of sloshing can project your waste into the SOG pipework. And stripping down the gubbins to get shite out of the blades is no fun at all.
2,356
10,238
see my previous post for a DIY SOG system without that problem..
Simon_H
Benfleet, Essex
Azalai
Thanks, I did read the DIY post. Personally I prefer to use SOG as when I come to sell the van it looks better on the 'For Sale' sign than "I plumbed in an anti-stink pipe myself" ::bigsmile:
2,356
10,238
Thanks, I did read the DIY post. Personally I prefer to use SOG as when I come to sell the van it looks better on the 'For Sale' sign than "[HI]I plumbed in an anti-stink pipe myself" [/HI]::bigsmile:
No no no .. :Doh:
you market it as having an EFPWGET System,, ::bigsmile:
"Environmentally Friendly, Powered Waste Gas Exhaust Toilet System" .. :roflmto:
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Why not just disconnect the pipe before moving, and use the bung to stop the chewed bread emigrating???
Armytwowheels
6,476
14,883
Market Harborough
Since 2011
For goodness sake! That's far too simple:Doh: and doesn't cost any money, that will never do, tut! :RollEyes:
