Red_48
- Aug 26, 2018
- 55
- 21
- Sprinter CDI313 LWB
- Newbie
The ones with automatic transfer do it, ones that don’t can easily be installed that way using and external purchased device or a suitable relay in seriesJust learning about inverters...
Does anybody know of an inverter that can isolate when on shore power, i.e. autosense AC power coming in from the shore (terminating on busbars) and isolates itself preventing AC power coming from both battery and shore?
Or do they all do this?
No, that just means it turns off I assume.Thank you Eddie
Sadly I have already purchased a Victron Energy - Charger 30A 12V which is not an inverter, so I would need to buy a separate unit.
When shopping Invertors, I know I want a pure sinewave model. This model states it has "High voltage battery stop", is this the same as "automatic transfer"?
Or, simply put the AC main on the Normally Closed contacts, so the relay only being energised when the inverter is ON.I rigged up an automatic change over relay and wrote a thread about it on here somewhere. Others have also done it and others have fitted manual changeovers.
The one circumstance when being automated isn't perfect is if you have a very low amp supply. I've come across 3A in a few places. This isn't enough to run a hairdryer or my coffee machine so I had to unplug the EHU cable and run the inverter. You could get around this by adding a switch to force the relay to change instead but the need hasn't arisen frequently enough for me to have bothered.![]()
Eddie when you fit one of those does it render the existing Electrobloc charging of the hab batteries redundant? And does it deal with solar as well?Starting from scratch an Inverter/Charger is the best bet as it would enhance your 3amp up to the capacity of the inverter to avoid any issues
The electrobloc charger is disabled. There are no issues with Solar. I have 2 Lithium batteries, 3 x 150w solar panels and the Victron Multiplus 2000/80 and it all works a treat. On my camper there are three very large domestic TV's run from a HDMI distribution unit, a Humax 1Tb Freesat Digi box all mains, so the inverter is rarely off.Eddie when you fit one of those does it render the existing Electrobloc charging of the hab batteries redundant? And does it deal with solar as well?
Thanks. Only you and Eurotunnel would ever call what you have got a "camper"!!!!!!!!!!!!!!!!The electrobloc charger is disabled. There are no issues with Solar. I have 2 Lithium batteries, x x 150w solar panels and the Victron Multiplus 2000/80 and it all works a treat. On my camper there are three very large domestic TV's run from a HDMI distribution unit, a Humax 1Tb Freesat Digi box all mains, so the inverter is rarely off.
Luckily my wife insists on having a hair dryer and tongs I get Wife approval for all of this, and cost, whilst a consideration is not too high on the list.
Out of curiosity do you have a ball park figure for how much that would cost to fit in my 2015 Hymer B678?the Victron Multiplus 2000/80 and it all works a treat. .
The usual scheme is to connect the inverter output to the 240v sockets only. In your case through a double pole switch. I used a relay but a manual switch would be fine.I'm happy to manually switch the power source from shore to inverter and forego any "auto invert during a shortfall" but I'm concerned that the shore power charger will be energized by the inverter, creating a loop. See diagram.
https://www.dropbox.com/s/ecp2x13uqqxrm6v/Inverter.png?dl=0
I'm struggling a bit with your terminology but I think I understand.Are you suggesting I need to isolate the shore charger when the inverter is in use?
That won’t work - you are creating a loop whereby the charger could take power from the inverter to charge the batteries that power the inverter. I suspect something would go bang.I'm happy to manually switch the power source from shore to inverter and forego any "auto invert during a shortfall" but I'm concerned that the shore power charger will be energized by the inverter, creating a loop. See diagram.
If I'm reading your diagram correctly then your inverter will be damaged as the output from the inverter and the shore power are connected together. I don't know if it would be damaged if the inverter was switched off but it would certainly be damaged if it was switched on by accident as the phases would be out of sync and you could have a virtual short circuit. The sort of systems used in domestic solar installations are clever enough to sync the inverter output to the mains so that electricity can be sold back to the grid but I don't think a typical MH inverter can do this.Thank you. I have amended my diagram to reflect a Single Pole Double Throw manual switch on the positive wire between the existing shore charger and the proposed inverter (see link below).
This would effectively isolate the shore charger or inverter.
The switch position would be moved from Inverter to Shore when connected to shore power. But I'm unsure whether the inverter would be damaged if the switch was left set to the inverter when connected to EHU?
