Small solar panel query (1 Viewer)
43,365
49,706
I just can't get my head round it.
Possibly a 50watt panel, I assume 50watt as I haven't seen it.
Multi meter onto Pos and Neg wires and reading 21volts
Its been wired direct to battery with no regulator.
Due to it being such a small panel Will the battery self regulate the voltage down to a more useful voltage or is it just banging in 21volts?
The battery is totally knackered....
After a 24hr charge it shows 13.7v
Only 1 strip light running the voltage drops to less than 5 volts in around 5 minutes.
Aug 25, 2016
1,098
5,754
Taynuilt, UK
Hymer 655 Starline
Village idiot
It will kill your battery or even a new one get at least a cheap solar regulator on it
It’s not the volts it’s the amps that are important
43,365
49,706
It will kill your battery get at least a cheap solar regulator on it
My thoughts too but many of these small panels are chucked on the dash and clipped to the battery not needing a regulator.... But the question is do they still bang out 21volts or are they self regulating in some way.
It wouldnt surprise me if it isn't a larger panel anyway.
Tombola
4,847
15,759
Merseyside
Rapido 8094DF
too many volts but only 4 or 5 amps. the panel will just keep climbing the volts and boil it.
you do need a regulator Im afraid
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
No. They couldn't bung out 21V whilst connected directly to a lead acid battery. If they did, they'd be pumping 100s of amps into the battery and they simply don't have the power to do so.
However, what will happen is that they will do a reasonable attempt at bulk charging at maximum rate (but somewhat inefficiently due to lack of MPPT). This means the voltage will slowly rise up to 14.4V, just like with a smart charger.
However, once bulk finishes, it will fail to move to absorbtion phase, let alone float. The voltage will go way above 14.4V and result in excessive gassing, eventually destroying the battery.
You may get away with it with a very low charge rating, (ie. 0.05C), as the overcharge will be slight. With a 50W panel, not a chance.
43,365
49,706
Just realised where the flaw in my thinking is...... I'm thinking those 5watt panels supposedly to trickle charge a battery.....not a 50watt.
The previous owner of this shed knew nothing about it but had a tinker anyway.
Fridge didn't work.... Yes it does.
Didn't know how to light the gas fire... Gas valve turned off on manifold.
Just the little things like that.
18,041
48,179
To answer your original question the 21 volts you measured would be the open circuit voltage of the panel without load. When attached to a battery the voltage will fall to something around 13 or 14, the exact amount will depend on the state of charge and the amount of sun. It will certainly charge the battery like this and some cheap controllers do exactly this - connect the battery directly to the charger. But these controllers sense the voltage and disconnect the battery when the voltage reaches a higher limit. With use the battery voltage will reduce and at a set lower limit the charger will reconnect the battery. This isn't a very efficient way of doing it but the system works. These are called shunt chargers.
Just seen your edit, if it is a 5W panel it won't do any harm connected directly - or much good but probably better than nothing. :)
andy63
4,672
15,018
south shields
since 1990
Thats basically what any true pwm controller does.. or at least that was my understanding...it connects the panel directly to the battery and acts as a switch to control the charge ..
Andy
43,365
49,706
Certainly not a 5watt jobby.
My mate had a look on the roof and said it was around 18" Square so I assumed it to be around 50watts.
But he has a strange perception of distance and weight... It could be 3ft by 2ft for all I know
It will remain disconnected until I get my spare reg on it to test.
Reactions: DBK
Oct 8, 2014
1,642
3,033
Wiltshire
Autotrail Excel 600B
Previous VW Camper + Caravan
Amazon product ASIN B071ZZ2S84
I've got two of these - one on my shed, and one on my boat. Cheap, but they seem to do a good job. The boat batteries (40 watt panel) were sat at 13.5v after last year's lockdown, and engine started instantly.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Andy
The difference between a PWM and a "shunt" style is that the PWM will rapidly connect and disconnect the panel to give somewhere between full and no charge, so can do effective voltage regulation. Basically, the "shunt" style has to switch off and can't perform absorbtion phase, whilst PWM can.
MPPT is more clever in that it can have different voltages across the battery and the panel, so can optimise the panel voltage for its maximum power output during the bulk phase, which might not match what voltage the battery is producing. PWM has no choice but to run the panel at battery voltage, which may reduce power output by up to 30% depending on how mismatched they are.
andy63
4,672
15,018
south shields
since 1990
That would be my understanding..the fundamental difference between pwm and mppt is that there is no direct connection between panel and battery with a true mppt controller.. whereas there is with a traditional pwm..
Andy.
Dec 2, 2019
3,610
7,801
Amersham
van conversion
Since 2019
A PWM pulse with modulator will only modulate when charging reaches constant voltage ( absorb). Until then the panel is directly connected to the battery, and the battery voltage and resistance is doing the pulling down of the panel voltage. Once the CV is active, the PWM it switches at very high frequency on and of to maintain the voltage set. So until CV mode the PWM does nada. The battery pulls the panel down.
You will end up with amps in -amps out, as long as the panel voltage can stay above battery voltage.
The mppt is a dc buck converter, you still need higher panel voltage to charge a lower battery voltage, with added dc conversion, that results in power in- power out. No extra voltage is lost. The added bonus is, it tracks the maximum power point of that time. The more samples it takes the more modulation will do. There is even a therm for fast and lazy tracking.
Even more clever mppt chargers used on wind turbines that have buck AND boost converter, you can have a lower OR higher input than the battery.
43,365
49,706
He has a new 110ah battery coming tomorrow and the panel WON'T be getting connected until everything else is checked and sorted.
Think I've located the split charge and fridge relays so that's the next thing.
Water pump was running very slowly and needed a tap with a spanner to get going.... Tried it with the valve block off, no better so took it off to have a look.
Took the armature out and the fixed magnets were stuck to it. They had debonded from the motor case. I'm surprised it ran at all.
Dec 6, 2011
11,618
25,519
South Wales
Coach built Adria
You have me thinking now. I only mentioned today it looked like a pushrod engine.
There is a plastic belt cover but it may only be the injector pump belt.
Everything else is by visible aux belt.
i am really not sure !!!! when ford introduce belts and on what engine.. i guess its not difficult to find out with that cover off.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
I remember changing the cambelt on a 1983 Ford 1300 CVH when I was at university. Although hopefully, this doesn't have that particular engine!
