Sky Eye Link Problem (1 Viewer)
Biggles
151
33
Autotrail
Hello
I have set my sky up and done EVERYTHING to the letter 5 times over to get the RF2 link to work. No matter what I do I can't get the box to output the 9v required to make the eye link work.
I had the same problem several years ago with a box at home and then you could speak to a real engineer. Then I was told how to do it by entering a deeper menu than the 0>1> select.
Can anyone help with getting this RF2 going?
Biggles
wanttobeaway
55
on tour
white one
only 3.2 and counting
I am sure you have to turn your rf output on in one of the settings not to sure which one as its been over 6 years since I had one and cannot find it on the sky+
wanttobeaway
55
on tour
white one
Found it press services, then 4, then 01, then select, then rf outlets, change to on, then save
hope this helps
Biggles
Biggles
151
33
Autotrail
hope this helps
Thanks everyone for the suggestions so far.
Just to clarify I have done everything both SKY & the instructions have told me to do. I do mean EVERYTHING!!! corectally and to the letter 5 times over.
What I am after is a deeper menu than the one already mentioned here which I have done many times over to no avail.
Biggles
43,365
49,702
if you've done everything five times over then it could be a fault in the equipment.
different thing but the remote that came with my tv doesnt operate the volume.....simple fault.
Phil
226
Herts
10 years
Have you tried a different digibox as it really sounds like the one you have is faulty?
I have had many sky boxes over the years and both the rf outs have worked without any resetting.
Phil.
ps. it might be worth looking inside and seeing if the wire has dropped off the back of the connector. Disconnect from Mains first of course.
Biggles
Biggles
151
33
Autotrail
Phil.
Yep did that too. Nothing like a fuse in there to change, nothing seems blown either.
Munchie
8,921
12,581
Camping Les Vigeres
Font VendĂ´me
Give me a few days (Tues Wed) when I go to my van I'll get the destructions for mine and will post them for you. ::bigsmile:
By the way you do have to switch the RF on. I remember that much.
Biggles
Biggles
151
33
Autotrail
All done the box says RF on and setup saved but thanks for the offer.
