Sink is blocked (2 Viewers)
peter H
1,313
665
Neath, South Wales
Low profile
Nearly 4 years
Got a problem in shower room. Sink very slow draining and think shower tray blocked.
Probably soap scum, tooth paste and hair etc.
Anyone know if using a domestic drain unblocking liquid like Mr Muscle is a problem ?
Peter
MikeandCarolyn
2,170
1,468
Worle,North Somerset
We use Thetford grey waste freshener poured down sinks to freshen grey waste tank-a by product seems to be that the sinks always drain faster afterwards ::bigsmile:
Mike.
Apr 13, 2012
5,545
18,776
Mobilvetta Euroyacht
1996, then break 'til 2011
Have you tried just pouring boiling water down the plug hole? - works on my sink when it slows down
gorsty
67
21
uk
newbie
You uselly find it is hair and grease from shower gell and shampoo uselly the center of the waste comes out so you can clean it if not carn,t you take of the trap and clean out just a thought
dave :Smile:
43,337
49,538
I use Buster Kitchen Plughole & Sink Cleaner on sink, shower and washbasin plugholes after every trip. Lidl and Aldi have it as a special fairly regularly so I stock up then rather than pay normal supermarket prices.
Spoken like a true Northerner :thumb::roflmto:
17,635
43,369
never pour boiling water down a plastic sink or shower tray unless you are happy to replace them when they split. even down a stainless steel or enamel sink can be dangerous because the plastic pipes become loose if over hot. a blockage will hold the near boiling water up long enough to cause an issue
bobandjanie
8,165
15,812
Javea, Spain
Pilote V600g
Peter fill a 2litre milk bottle with warm water, put it in the plug hole and squeeze. :thumb:
peter H
peter H
1,313
665
Neath, South Wales
Low profile
Nearly 4 years
All done now.
Bottle of jollop from supermarket, shared between the three plug holes.
Left to stand for an hour, as it was too wet to go outside to the van.
Flushed out with warm water.
Sink empties now with a resounding gurgle.
Thanks folks
Peter
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
Last time i came to throwing up-- had to sort out a split sink in a MH, i had to remove the lower pipe ect ,full of someone elses slimey stuff :)Eeek:) phew
