Kannon Fodda
- Feb 26, 2019
- 2,600
- 8,055
- Autotrail V-line 540
- I Make Schoolboy Errors!
I recall last summer the shower/wc room in my PVC got very warm. I could emerge sweatier from a shower than before I started
The van has a small sized mushroom vent. The internal grille and so tube diameter is an approximate 75mm (3"). Looking within there may be a mounting that could have taken a light fitting, but Autotrail didn't wire up for this or put in a bulb.
I can see a few mushroom extractor fan assemblies online with fans, but the only dimensions suggest the tube is probably bigger than my fitting. I don't want to start taking the whole thing apart and enlarging holes in the roof.
Has anyone fitted a 12v fan to this type of vent. If so what?
Also would it be sensible to try and take a power feed from a light fitting in the shower/wc or is that likely to be inadequate and overload the wires and fusing? Wherever I get the feed from will need to be fairly easy to get to as I don't want to be pulling the internal finishes apart.
