Help
Just replaced the ageing leisure batteries on my Burstner Elegance and now can’t get any power to the any of the 12v users. The control panel powers up and shows leisure battery voltage is healthy (measured at 12.6v prior to fitting) and the batteries are taking a charge from EHU. I followed the following sequence for isolation and removal
Switched off control panel (model LT510)
Covered solar panel
Removed +ve and -ve connections into solar controller
Removed solar connector into EBL
Remove 5A and 50A fuses at battery
Disconnected - ve on both batteries
Disconnected +ve on both batteries
Reconnected batteries
Refitted fuses
Reconnected solar
Turned on control panel.
Not quite panicking yet as we aren’t off on the ferry until the 1st September but will start panicking shortly if I don’t get it sorted
All help greatly appreciated
Covered solar panel
Refitted fuses
Reconnected solar
