- Jan 31, 2022
- 311
- 149
- 70s camper,Weinsberg
cheers did have a quick search and main correspondence was about astra 28 but not sure which this is on our, cant reach roof to check the degree angle.There are loads of threads on MHF about Astra 2 Default transponder....
You need to do a bit if searching...
I only use Oyster stuff....which has pre-installed Sat settings.perhaps yours does also...see if your dish moves from 19° to 28° when you select Astra 2...then do a full program search....
thanks for that struggling with ours being only in German !!It all seems to be automatic ... found this: https://download.ten-haaft.com/BA_Anleitung/BA_english/EN_AH_Oyster_V_Premium_3.150.0116.pdf
that would be brilliant, will have a play this weekend and if not speak next week. On plus side havent seen eastenders all week...3crispies the chances are that the TV just needs a new list loading onto it with the UK channels. The Oyster takes it's cue from the TV so will lock on to the satellite of the currently selected channel. If you haven't sorted it yet give me a call and I can arrange to send you a list and explain how to load it onto the TV.
Send me your email or email me here: anthony@oystersat-tech.co.uk and I'll send you our latest list to load onto the TV. The on screen menu's could well be in German as it's an imported system but I can sort that in a few seconds if you are to give me a call when with it.still struggling have set to astra 28.2, transponder to 10847.00 although preset is 10714 done auto search and still no channels in english infact channel list is still german even tried digital Tv instead of satellite
