Sagent display on Autotrail (2 Viewers)
Scout
3,959
121,359
South Yorkshire
chic c line
My (new to me 05) Autotrail Scout has the Sargent ditgital display system, there is a couple of small problems will it,
The waist water indicator does not seem to be working it does not show any increase in volume when water is drained into it, it just shows 0% full. I suppose it could be a faulty or stuck sensor float? Or the Sagrent system could be faulty or possibly just need reprogramming? As suggested to me by autotrail customer service.
The outside temperature is flashing -26deg according to the “book” this means a faulty or damaged probe (where is it situated ?) or the connection is not made to the main unit? To add confusion it also seems not all vans have this sensor, so how do I find out ?
The van is in having its hab service, and they are going to look at these faults, but any info I can get will help my understanding of this unit and make sure I’m not bamboozled by the service people
thanks
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
the waste water float may well be gummed up with fat, try putting some washing powder in the tank and going for a drive to slosh it around abit. once cleared you should have full function back. If you do this at least once a year it should keep it free.
Scout
Scout
3,959
121,359
South Yorkshire
chic c line
seems a good idea, if they cant find a proper fault durring the service I 'll fill it up with warm soapy water and drive like Jenson Button...
S
sinbad1
As wildman say's probably sensor gummed up, think ot only registers 0%, 50%, 100% though
As for your temp sensor ,could be that it is not fitted and may be an extra, you can buy the sensor from the suppliers for about £9
Which control pannel do you have?
Regards
territo
25
In motorhome or in peru
Sargent control system
I understand that some of the control systems only show the waste tank is 0% or 100% and nothing in between.
If you have problems or questions about the Sargent systems as I did their man at the factory was very helpful. He is on 01482 678981.:thumb:
Scout
Scout
3,959
121,359
South Yorkshire
chic c line
Regards
mmm not to sure atm vans away being serviced, but I get a look later
Scout
Scout
3,959
121,359
South Yorkshire
chic c line
thanks for that...
bald eagle
4
here,there and everywhere
coach built
since 1998
We have a v reg mohican and the outside censor just comes out of
the floor underneath the m/h sticks out about an inch,it is directly in
line with the control panel.hope this is of some help.
regards
bald eagle
S
sinbad1
Ok maybe you will see your control pannel Link Removed lot of info on the site you may find useful as well as tech data downloads .
Regards
Scout
Scout
3,959
121,359
South Yorkshire
chic c line
Regards
cheers its the ec200..
very usefull site,
Scout
Scout
3,959
121,359
South Yorkshire
chic c line
regards
bald eagle
thanks will hace a crawl around later
lufcdave7
163
Rochdale
1 year
Hi Seb
Territo is correct...despite what the manual says the waste tank only registers 0% full and 100% full, not trusting what the dealer told me I filled the waste tank to the top and sure enough it registered 100% full and started flashing.
Scout
Scout
3,959
121,359
South Yorkshire
chic c line
Hi Seb
Last time I was out in the m/h the only way I knew the tank was full was because it was overflowing out of the overflow making a nice puddle on the pitch.. I'm sure the display was still on empty
S
sinbad1
looks like the 50% is optional:Sad:
I guess if your fresh water tank is full and waste water empty to start with, then when the fresh is empty the waste will be full.
Assuming they are both the same size:thumb:
davetthedon
141
Malvern, Worcestershire
GreatBig Bugger
If yours is similar to mine (the chieftain) the outside sensor is in a direct line underneath the control panel, hanging outside under the chassis. It looks like a piece of black and white speaker cable, with a shrinkable sleeving over the end. The sensor is inside this sleeving. It is yellow and about the size of a map-pin pinhead and has 2 wires coming out of it. This is what broke on mine, (I managed to solder mine back together though) you can source them on rs components and maplin they are called thermistors Link Removed . :thumb:
This is a bit cheaper than one from Autotrail, if you can use a soldering iron.
The other end of the wire is attached to the back of the control panel, and if the same as mine, has enough wire on it to actually install a set of speakers too!!. There is another pair of wires for the inside sensor, this is high up abve the control panel, in the cableway.
ATB
DaveT
davetthedon
141
GreatBig Bugger
:cry::cry::cry:
I think I'll set up a bucket under the overflow, when I hear it dumping I know its full:ROFLMAO:
Surely, if its optional there must be a take-off point on the circuit board for another sensor? Why not fit a simple resistance sensor in the side of the tank 1/2way up?
lufcdave7
163
Rochdale
1 year
Hi Seb
sounds like you have a problem then, two ways to go.....
1.) the manual says remove front trim of display, undo the two small screws, pull panel forward and pull out the multi connector cable, this resets the panel and MAY solve the problem.
2.) if above fails ring Baldwins Motorhomes, ask for Guy in service, what he doesn't know about Autotrails is not worth knowing and a more helpful, friendly person you'll struggle to meet. Tel 01422 382333
cheers
Luffy
Scout
Scout
3,959
121,359
South Yorkshire
chic c line
Hi Seb
done that, seems to make no differance
cheers
Luffy
might have to resort to that later
