Rooftop tent on a small van (1 Viewer)
Aug 30, 2021
4
Not owned yet
So I have a grandiose idea of using a small van as a part-time tourer, by building a sit down bathroom and kitchen in the load bay, and having a rooftop tent on top for sleeping. The problem is that most vans/roof bars appear to have a limit of 75kg to 100kg. Is there any way to increase this, or shall I have to look at alternatives?
B
Aug 30, 2021
4
Not owned yet
This then begs the question; are the "max roof loads" provided by manufacturers for static or dynamic weights? I'm guessing now that it must be dynamic, as there's no way that two people plus tent would be less than the stated 75kg/100kg weights I've seen.
Also thanks much for that video :)
Apr 22, 2018
6,826
12,585
Herts.
Adria Coral lowline
If you are adding a roof tent these often have a solid base so massively reinforce the bars, and are also spreading the weight. I wouldn’t personally be worried about it. Also I suggest you look what a tradesman will load onto a set of roof bars, and then often in a single place.
My truck and roof tent
I personally wouldn’t go for the type of roof tent you’ve shown above due to the fabric construction, we prefer the hard shell
B
Aug 30, 2021
4
Not owned yet
I checked the website for Tentbox, and they do hardshell tents as well, that's just the "entry level" model.
Apr 22, 2018
6,826
12,585
Herts.
Adria Coral lowline
This is mine.
Jamesh
2,200
3,839
Van conversion
Caravaning since 2010
What van do you have?
If it has a flat roof could you not secure the roof tent with through bolts. Dummy bolts could be in place when your not using the tent?
Just a thought?
Cheers James
B
Aug 30, 2021
4
Not owned yet
Hi James,
I've not yet bought the van. At the moment, the most likely candidate due to a combination of availability of parts, price point and just generally seems the best shape for what I want would be the Ford Transit Connect.
It does indeed have a flat-ish roof, and quite a few that I've seen already have roof bars installed.
Thanks for the website, Landy Andy, I shall add it to the research :)
