Rm6271 fridge problem (2 Viewers)
Clive 1611
Autosleeper amethys
Hi all, and thanks for allowing me on the forum, I recently changed the thermocouple on my fridge I have broken the cable going to the gas lit warning light which activates when the gas goes out, this part is no longer available, is it safe to use an optional neon warning light using the same connections, this light is an indicator light not a toggle switch, the fridge is electric ignition, but not automatic changeover, thanks for any help
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
w2f
Depends what voltage the original warning light worked at. You might be able to use an LED and resistor. Can you measure the voltage when the gas goes out?
Andy_sim
Had one caravan now
Hi there, I have the same problem, managed to get a 1200mm super universal thermocouple which has the fridge working. I think my neon has been broken a long time and just discovered the break. I think it is just to advise it is lit. I will measure voltage when I get home out of intrest.
