Copilot 1188
Hi I've been told that you can retrofit cruise control to my 2.8 diesel Fiat Ducato Bessacarr, any advice welcomed
Sorry but it can be done pre JTD but had to look up as mine was a long time ago, worth a call if this is what you haveHad my 2.JTD and worth every penny.
Needs to be the JTD and this can retrofitted
I find the limiter a pain in the butt, never use it now. When I used it driving through a town, when I pulled out onto the bypass went into panic mode when I put my foot down, thought the engine had died. Prefer to use the cruise in towns the Fiat one works down to 30 kmh.Get a system fitted that also has a limiter. It helps a lot, and I use it more than the cruise to be honest.
I use mine a lot in France for the 80km speed limits. I was using the cruise but every time you come to a bend, turning, village etc I slow that turns off the cruise. If I use the limiter then I’m still driving the vehicle but only to a max of 80kmh. If I want to over take just hold acc pedal it over rides cruise until I release it. Maybe yours is a different system. I’ve also got two memory presets which I can program for things like village speed limitsI find the limiter a pain in the butt, never use it now. When I used it driving through a town, when I pulled out onto the bypass went into panic mode when I put my foot down, thought the engine had died. Prefer to use the cruise in towns the Fiat one works down to 30 kmh.
Slightly off topic, but wish that a proper speed limiters could be retro fitted.
Not the pathetic apology from the factory
Mine is the standard Fiat one. on an X290.I use mine a lot in France for the 80km speed limits. I was using the cruise but every time you come to a bend, turning, village etc I slow that turns off the cruise. If I use the limiter then I’m still driving the vehicle but only to a max of 80kmh. If I want to over take just hold acc pedal it over rides cruise until I release it. Maybe yours is a different system. I’ve also got two memory presets which I can program for things like village speed limits
I fitted a retro cruise control system which has a user settable speed limiter and 2 user settable cruise speeds as well as the normal cruise control to our van.
Dead easy to fit and not big money.
PRECISION CRUISE CONTROL FIAT DUCATO
The PRECISION CRUISE CONTROL FIAT DUCATO is an Original Equipment quality Cruise Control system. This is a Fiat Ducato Cruise Control System and contains many enhanced features such as multiple memory settings and independent speed limiting.www.ncs-systems.com
I didn’t have to do any setting up, just had to make a hole for the control arm (where the Fiat one would go) and splice into two wires, the other connections were via pre-fitted plugs. Works very well.Great to hear that it's easy to fit (klaatu says this too). The ncs-systems web site says that "This unit comes pre-programed for your specific vehicle " so no need to set up anything (apart from the parts fitting and wiring)?
