Retro fitting Corian worktops. (1 Viewer)
Apr 17, 2016
512
570
Peterborough, Cambridgeshire
Carthago Chic E Line
Since March 2004
Does anyone know if it is possible to retrofit Corian worktops, including the sink, in a motorhome? If so any names available please?
Regards
Lazyboy
Oct 29, 2016
4,511
53,070
Surrey
Carthago C Tourer
A decent kitchen fitter is your man/woman/LBGT/alien.
The sheets can be purchased fairly easily, cut easily, and those in the know will glue up any facings and weld up the joints so as to be almost invisible.
Good luck.
LES
R
Robert Clark
I’d speak to your local solid surface fabricator as they might have off cuts which would be long enough for your project.
Feb 20, 2010
484
873
winchcombe
swift sundance 630g
I wouldn't go with the stuff got it in our kitchen dont see the facination with it.Very heavy we got a specalist in cost a fortune not worth it imo.
Jul 29, 2007
6,554
39,757
Ipswich
RV and PVC
30 years
Never found Corian heaver than standard worktops, now if your talking about granite they are heavy but make superb worktops.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Regards
Lazyboy
Yes you can. If you've not got a lot of payload to play with, then you should not.
Mar 30, 2019
2,781
5,158
Cardiff, UK
Since 2016
You definitely can. It's a bit of a specialist job as you need specific clamping and sanding / polishing equipment which a regular kitchen fitter won't have. I'm fairly sure you can get a trendy 12mm (or possibly 15mm) thickness now which would help with the weight issue.
MisterB
5,958
13,315
Adria 670 SLT
We're having solid laminate in our kitchen at home. Might be an option to consider? Nice thin profile and not overly heavy.
Nov 30, 2009
6,548
149,209
Pickering
PVC the PUG
Ralph fitted it in ours when he converted it. We think it really finished it off. Worth the extra cost and we had lots of payload to play with.
He also fitted a very handy drop down table, the other side of the hob, which flips up, then back down when not in use.
Giving me lots of work space for a PVC.
Unfortunately I’ve not a photo of it up.
Mar 30, 2019
2,781
5,158
Cardiff, UK
Since 2016
We used to install that in school laboratories years ago. You need to be aware that the decorative surface will mark just like a normal laminate worktop. It's not quite as durable as quartz
Jul 29, 2007
6,554
39,757
Ipswich
RV and PVC
30 years
It will scratch and burn agreed but you can polish it out unlike laminate.
Mar 30, 2019
2,781
5,158
Cardiff, UK
Since 2016
I was referring to the solid laminate which has only a very thin decorative surface. I agree that Corian or any of the other 'solid surface' tops can be sanded and polished to remove scratches
Jul 5, 2013
11,742
13,735
Had Corian worktops fitted at home last year and am very pleased with them. Really need a trained experienced fitter (not your standard kitchen fitter) to make and fit to ensure that the joins are invisible.
AFAIK Corian is only made in 12mm thicknesses. The edge can be thickened up by gluing layers together, to make 24mm or 36mm around the edges. Unlike Ernie Wise a good fitter will make sure you can't see the join.
Jul 29, 2007
6,554
39,757
Ipswich
RV and PVC
30 years
We never did many so weren't accredited so no guarantee from Corian, we just used to fit 3/4 marine ply baseboard and help the Corian guy from Colchester fit it, so it then had a ten year guarantee, something like £100 a metre from memory same as we charged for Granite.
tkk
Jun 9, 2014
357
274
notts
Frankia i640
newbie but learning fast
Have got it. Main drawback is it stains easily, coffee,wine etc,
MisterB
5,958
13,315
Adria 670 SLT
i am hoping that things have moved on a lot since then, as things tend to do ......
Solid Laminate Worktops
Constructed of several sturdy layers, these surfaces are a high-performance option with a slim profile. Solid laminate worktops are incredibly practical as they are completely waterproof, resistant to a high level of heat and durable against abrasion and impact.
Feb 4, 2016
2,784
2,128
West Sussex, UK
Hymer B680 Starline
Long term a few years now.
Got Corian worktops in our 5th wheel , island kitchen top and counters . Had no problems so far .
