DanielFord
- Jun 1, 2013
- 3,020
- 3,086
Thought I'd post this up. My van got an advisory on the MOT, discs worn and rusted. Did a search on YouTube and google, and I was amazed that there were no instructions, so here goes:
First the tools you will need 14mm hex bolt, 6mm hex bolt, 17mm socket, 21mm socket, hose clamp, impact wrench, long reach 12mm socket, 11mm ring spanner, piston rewind tool, brake bleed kit, cable clamp and a bloody big hammer. In addition to this, I needed a 4 foot breaker bar (frozen bolts).
Now you have the tools (and hopefully the replacement parts) you are good to go. Incidentally, I ordered my parts from brakeparts.co.uk half the price of EuroCarParts, and the pads came with a fitting kit for free!!!
This is a very rusty example, but you get the idea! First job is to remove the calliper. If like me you got a fitting kit, you can pop off the rubber end caps and throw them away. Underneath are the 12mm hex bolts, slacken the top bolt, it shouldn't be too tight, and remove the lower bolt. Now apply the cable clamp to the brake fluid hose, attach the brake bleed kit and open the bleed nipple (11mm spanner). Using a tool like a screwdriver, force the pads away from the disc in a way that causes the piston to compress, only a small gap is needed. Close the bleed nipple, and using a pry bar lift the calliper up to reveal the pads.
I jumped ahead in this photo and totally removed the caliper and placed it on top of the assembly. It is important that you do not allow the calliper to hang on the hose, you will damage it! Also, if you have a pad wear sensor, you need to unplug it and feed the wire back through the calliper.
You can now go ahead and reattach the bleed kit (with the cable clamp in situ) open the bleed valve and rewind the pistons (sorry I forgot to take a picture) next picture does shows the cable clamp applied though, so bear with me. Next job, and it is a big job, removing the calliper carrier!
It is absolutely certain that you bolts will be frozen solid, providing you are replacing both discs and pads I advise a good drowning in WD40 and taking a good coffee break at this point. When you have consumed your tasty beverage, you now need the 3 foot breaker bar and the 14mm hex bolt, the carrier is held on with 14mm hex bolts. In this photo you can see my hex bolt adaptor on the top bolt (also the fact the I have used a generous dose of WD40):
With the calliper carrier removed, place it to one side. There are two disc locator bolts on the discs, these will also be frozen solid, get the long reach 12mm socket and impact wrench to undo these. If you have these tools, I don't need to explain how to use them. After you have removed the retaining bolts, the disc will need considerable convincing to come off, use the hammer! You should end up looking at the bear hub:
Now time for a bit of elbow grease, using a wire brush, clean up as much of the rust as you can on the hub. Next apply a good dollop of copper grease to all of the thread holes (it may help for next time).
Time to reassemble, make sure your hands are clean (or change gloves) offer up the new disc to the hub, and align the holes. Insert and hand tighten the two retainer nuts after applying a little copper grease to them.
Take the calliper carrier and give all the mating surfaces a good workover with the wire brush, try to remove all evidence of brake dust. Reattach the carrier and make sure the bolts are very tight. Again in my case I had a fitting kit, so at this point I inserted the new pad guide springs. Take your new pads out of the box. If you have a wear sensor wire, it is the one that goes closes to the piston in the calliper. Insert the pads into the carrier, a bit of wriggling may be required, they are a very tight fit. Now insert the top calliper bolt and swing the calliper down, again, a bit of wriggling may be needed, you have brand new components, it will be a tight fit. Also, if you have a wear sensor, you need to thread it through the calliper, it is extremely tight to get it through! Insert the lower calliper bolt, tighten both calliper bolts, but don't go mental, they only need to be tight, not stupid tight. Reattach the rubber caps over the end of the bolts. Plug in the wear sensor (if fitted) Your assembly should now look like this:
If it does, congratulations, you have finished, reattach the wheel and lower the vehicle to the ground, then start again on the other side
- First job obviously slacken the wheel nuts using the 21mm socket, I used the breaker bar for this, and it was still hard work. I think the last tyre fitter went a bit mental with the air wrench!
- Jack the vehicle up, make sure that the wheel is clear of the ground, and then employ a secondary support mechanism, axle stands, or in my case another jack, you don't want 4tonnes of van landing on your head!
- The callipers are at the front of the wheel on the Ducato, so turn the wheel out at the front that you are going to work on, and remove the wheel. As a tertiary backstop I always put the removed wheel under the sill. Can't be too safe.
