Replacement Gas Struts (1 Viewer)
JackieP
666
1,400
Isle of Man
I'm ever so slightly annoyed.
I've carried replacement gas struts around with me for three years (a set blew on me once and I've carried spares ever since) and I decided to replace the old ones with the new ones today in the hope that lifting the bed might be easier on the old back.
Turns out the replacements I've been lugging around for the last three years are the wrong ones.
It's a good job my ex husband is nowhere to be seen or he'd currently be wearing them as a Prince Albert.
The thirty years old struts have lost their sticky label with the model number so the only thing I have to go on are the dimensions and s photograph or two.
Anyone know where I can buy replacements with only the measurements and photograph?
In the meantime I'll put the old knackered ones back on....
Ever so slightly annoyed....
MillieMoocher
1,118
10,642
West Yorkshire
Autosleeper Kingham
40 years under canvas: Motorhome 2016 To 2020
Now THAT made me laugh out loud :roflmto: literally and made Swmbo jump out of her skin!
Aug 4, 2016
609
1,381
Yorkshire
Vantage Neo
Since 2003
What sort of job is it fitting these on a RHD Hymer (only the sliding window on nearside) please
J
JackieP
666
1,400
Isle of Man
You can pay money to get it done but it's really not a hard job (if you have the right gas struts).
There used to be a comprehensive guide on the web somewhere showing how to do it. Sadly I can't point you in the right direction but I'm sure a search of YouTube might bring something up.
Xabia
1,186
821
Since 1996
If it's a later than 2006 model it is very much more difficult because of access problems.
Jan 27, 2009
872
3,362
Leyland Lancs
since 2001
This may be of help? (not done by me)
Pull Down Bed Gas Strut Replacement
"WARNING THESE STRUTS HAVE VERY HIGH PRESSURE RAMS"
This procedure can be done by a competent DIYer
To replace a gas strut it is very important to make sure that there is no residual pressure on the locating pins. To achieve this, the bed must be set and held as high as possible, using the travel strap. I found it easier if the bed was emptied including the mattress.
The split pins were then removed and the strut checked that it was fully extended by being loose on the location pins. I then carefully removed the drum end, pointing to the back of the van first. This to ensure that if there is any residual pressure remaining, the strut it would be travelling away from the windscreen. The new strut was then fitted in the same position and split pins re-located to secure the strut before lowering the bed.
I was able to do the above from the inside of the van, but some may find it as easy to do the above from outside by leaning through the driver's door and the sliding window.
I would recommend that both struts are changed. It is sod's law that you will remove the stronger strut first.
32,700
66,734
Excuse me for the question, but being as I am a shy retiring type who has lived a very sheltered 'naive' life ... what is 'a Prince Albert'? I don't want to risk googling it as I did that the other day looking for something and got an unexpected 'surprise' and don't need that sort of 'education' again!
:D
Jan 27, 2009
872
3,362
Leyland Lancs
since 2001
:D
Male Genital Piercings
Silver-Fox
9,281
29,249
Cheltenham Spa
Rapido
im a not so newbie
@Minxy Girl it was allegedly a piece of jewellery worn by Prince Albert in his manhood :D
Maybe for the gratification of Queen Vic :D
Feb 19, 2017
918
2,243
Leighton Buzzard
Ten years
We changed our gas struts, lessons we have learned.
1/ It's a tricky job, gave up and got our garage to do it.
2/ The original Hymer mattress is generally lighter than any replacement, therefore replacement standard struts may not make much of an improvement.
3/ Storing extra stuff on the drop down bed all puts pressure on the struts.
4/ Sgs Engineering also sell stronger struts, with hindsight that would have been a better decision!!
5/ In fairness to them they have offered to uprate ours which brings us back to point 1!!!
32,700
66,734
weekenders
2,659
1,968
Leicestershire
15 years
We got our new gas struts from SGS at Derby, if you take the old ones in they will match them by size and you can have stronger ones if you require, it is quite a hard job to fix, but perseverance is needed.
