Removing green mold off roof. (1 Viewer)
Mar 24, 2010
1,060
727
stoke on trent
relay lwb pvc
6 years
I need to clean up the roof of my PVC -the green slimy mould. What is the best way /stuff to remove it ?
Nov 6, 2016
1,288
7,164
Bury St Edmunds
Auto Trail Chieftain
Since 2015
If you have a Karcher pressure washer they do a low pressure snow foam lance attachment, works for me,
It softens the deposits thus reducing the amount of the old elbow grease necessary, so you will have some left for lifting of the beer / wine / drink of choice, when job is finished
Joe
Reactions: f6c
movan
21,492
121,101
Moving around
Burstner
since07
Fenwicks Caravan cleaner is pretty good at lifting it .. then just rinse.
Reactions: f6c
Jul 24, 2014
1,058
2,691
North cotswolds
Peugeot Boxer Symbol Auto
since 2010
Wet and forget, spray it on and the rain washes it clean, its a patio cleaner and a friend has recommended it, I haven't used it yet but will call company first for advice.
What I do use and its brilliant is muckoff also Grease Lightening, magical.
Feb 22, 2011
9,139
17,846
Newcastle under Lyme
Hymer B544 A Class
Since 2015
I would suggest just warm soapy water and a sponge.
That patio stuff is good for getting rid of the green algee but I`m not sure if the chemicals could have a harmful effect on seals, plastics or paintwork.
My roof is pretty bad but I`m not thinking of doing it for a few weeks until it warms up a bit.
suavecarve
7,166
36,938
Surrey/Hants
Rollerteam 685
July 09
Any sort of cleaning agent such as washing up liquid, get the wife up there with a soft broom and tell her to put the effort into the broom then make sure you were parked on a slope to let the dirty water run off, so you can tell how much you have work you have saved her.
John&Kate
310
266
Waterlooville
Since Sept 2015
Autoglym Caravan & Motorhome cleaner .. Then a hot wash with bucket of water and Autoglym shampoo which has a wax additive.
Apr 26, 2015
2,518
6,091
Ottershaw
Hymer S820
First motorhome May 2021
You could try Pro-Kleen mould algae moss remover, you dilute it as per instructions and spray it on using a garden spraying pump and then leave it for two to three days before washing it off, it's actually meant for patios and decking but in the FAQ's it says it's ok for motorhomes. It worked well on my concrete path.
Dec 20, 2010
1,622
2,919
birmingham
kon-tiki 669. mazda bongo
since2011
Brilliant stuff for patios, Clean patio as normal then apply Wet & Dry it then activates with the rain to keep the patio clean.
Back to tread .its says that it is suitable for caravans and motorhomes, but have not yet tried it. Will do a test patch when the weather gets better.
