Removing a Ducato swivel seat....Heavy or what!!! (1 Viewer)
Jan 19, 2020
188
522
DBM 7150
Since 2016
We need to change the leisure battery beneath the seat. I've undone the 6 screws/nuts holding the assembly down. I'd read on other threads the seat assembly was heavy but not quite so heavy!!!
We're only a couple of lightweights, so does anyone know of a knack of doing this or moving it just far enough to access the battery space?
Any help gratefully received...
Apr 12, 2012
1,698
6,386
N/E Lincs
Autosleeper Rienza
as above
Not a Ducati but when I had to access the batteries under the drivers seat in our Transit I tipped the seat towards the passenger side rather than completely removing it.
The passenger side was easier not having the bathroom behind the seat but it was certainly heavy and ungainly.
Jun 7, 2019
441
1,893
30+ years
I wanted to remove the drivers seat too, on our Ducato based Campscout. I just leant it back, being wary of the cables running through the center of the seat swivel. I had visions of the seat ejecting through the roof of the van if I disconnected them.
What exactly are they and is it ok to disconnect them?
Sep 17, 2017
5,522
10,322
Birmingham, UK
A-Class
Seatbelt pre-tensioner. Theoretically it can go bang. More likely, it'll just cause your airbag warning light to come on. Best to disconnect the cab battery and leave it 10 minutes before you play with it.
Jan 28, 2008
10,131
18,407
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
Just disconnect with ignition off it will only show a fault code if you switch ignition on while it's disconected
Sep 10, 2012
2,139
3,792
worcester
Sunliving van
Think this has got the picture of what I did. Slide it across making sure the wires are not trapped.
Aug 22, 2007
2,502
32,814
essex
2017 sunlight t69s euro6
i have 2 batteries under my drivers seat i have no choice but to remove it and as you have found out its very heavy .are you trying to move it while still attached to the swivel? if so dont do them separately as above do not turn the ignition on when you have undone the bolts for the seat you may be able to turn it so the back faces the passenger seat and tip it sideways then remove the swivel from the seat base take photos as you go for replacing it all
WJACC
Jan 19, 2020
188
522
DBM 7150
Since 2016
Yes, I am/was trying to remove them as one unit. So where is the best separation point between the seat and the swivel arrangement?
Aug 22, 2007
2,502
32,814
essex
if you slide the seat forwards and backwards you will see the six bolts that attaches the seat to the swivel ,you wont believe how heavy the swivel is on its own
WJACC
Jan 19, 2020
188
522
DBM 7150
Since 2016
I'll look forward to finding out :LOL: :LOL: :LOL:
Sep 29, 2019
3,065
7,086
Hymer Exsis
20 years
I thought I was going to have an anal prolapse it was so heavy.
I would get someone to help.
Aug 22, 2007
2,502
32,814
essex
ok pull the flap at the front of the seat down and you will se a yellow plug in there this is the seat tensioner plug look at it carefully and you will see how it comes apart then thats it
WJACC
Jan 19, 2020
188
522
DBM 7150
Since 2016
If it came to it I think I'd rather sit in the dark:LOL::LOL::LOL: Anything anal ain't for me!!
11,958
16,575
I used to let the seat with swivel still attached slide / rock forwards to rest on the steering wheel. I found that with a little care I could manoeuvre two lead-acid batteries into place and connect them.
Jan 1, 2017
1,161
2,618
eastbourne
van conversion, Peug
4 years
Good tip, I changed the base on my seat to a lowered one ( brilliant bit of kit) but I needed a special tool to lift the seat out , the special tool is called Neil the taxi driver , my mate whos built like a brick outhouse.
If you watch Jennings videos on youtube he is equally ironman , popping the seats out like they are a box of crisps, i tried it and nearly bust a bloodvessel!!
WJACC
Jan 19, 2020
188
522
DBM 7150
Since 2016
Having split the seat from the base I now know why the ******* thing was so heavy... There were two nuts to undo from the underneath as well as the 6 visible on the top. :LOL: :LOL: :LOL: It was easy when those had been dealt with...
WJACC
Jan 19, 2020
188
522
DBM 7150
Since 2016
So you didnt spend half an hour trying to undo the welded nut for the seatbelt fitting before realising its a welded nutā€¦ no one would do that would they? šŸ˜³
Not me (y) (y)
Aug 22, 2007
2,502
32,814
essex
i have taken the drivers seat out on 2 ducatos never seen bolts underneath just the 6 in the channels
Dec 6, 2011
11,627
25,557
South Wales
Coach built Adria
A question for those who have done this.....
I know I could look this up but feeling lazy today šŸ¤”šŸ˜‰
Did you nerd to disconnect the battery prior to unclipping the seat tensioner connections under the seats?
I am also assuming that if you switch on the ignition with the tensioners unplugged then it will require a reset via obd2.
Aug 22, 2007
2,502
32,814
essex
no need to disconnect but as you say dont turn the ign on
