Monkeynuts2215
Afternoon Campers Hi de hi, has anyone got any idea how to get music to play on my Pioneer dab radio. Thank you in advance.
Hi FigaroDoes it have Bluetooth or a USB input or aux input ?
It’ll likely only be a selectable option with a compatible USB stick installed.Hi Figaro
It has a USB hole to put the stick in when i look for the USB on the radio, it is sort of greyed out and doesn't allow you to highlight it.
Ours was only 12 quid no dab but any radio stations can be got on the phone via data anywayIf there’s nothing else wrong with your car stereo add a Bluetooth/FM adapter like the one on this link:
It’s what I use and like.
The little head unit brings playlist control of your smartphone.
Oh! Now I’ve got you switching from USB to a smartphone
That simple Bluetooth to FM only kit is a good option.Ours was only 12 quid no dab but any radio stations can be got on the phone via data anyway
Does it have an aux input jack ? If so you could play music from a phone or mp3 player.
Otherwise might be easier to upgrade to a unit with Bluetooth.
I think they're pretty cheap these days
As the TheBig1 says, it’s very wise to format the stick in FAT32 before loading your music on it, it’s what I’ve always done and had no problemsMost modern radio head units have a USB port. You select AUX or USB in the menu to play music from a stick. It also needs the USB stick to be formatted in FAT16 or FAT32 so it can be seen
Is that flat files usage a limitation of a VW’s Pioneer dab radio?Also, just paste your song tracks directly onto the USB stick, without folders or directories, as it will not read content within folders (usually)
Not sure, sorry. My Kenwood‘s states that only top level music files will play, and those in folders will not be recognisedIs that flat files usage a limitation of a VW’s Pioneer dab radio?
Not aware of it on other MP3 players.
I’m having my music in folders all the time
