Rapido bathroom door - can't open it (1 Viewer)
Gemini
7
Taunton
Rapido
I have a 709F and the bathroom door is closed and won't open. Please does anyone know how it could be opened without breaking the door?
makems
3,440
27,708
Ingleby Barwick,,Teesside
Sadly had to give up
Do you have a photo of the handle?
Ive taken these aprt before but sold our Rapido 3 years ago so my memory is rusty
makems
3,440
27,708
I think there is a small screw which holds the handle on the spindle which requires a very small allen key.
Once the chrime handle is off you can grip the square bar with pliers and twist to open the door.
Probably the springs inside the very cheaply made lock have gone. If you do a search on here I am sure you will find a thread where I gave the details of a locksmith who will fix it for £10 plus PP if it is the spring thats gone.
CWH
5,151
247,515
WildAx PVC
From November 2013
Are you inside or outside the bathroom? :eek:
G
Gemini
7
Taunton
Rapido
Thanks for replying so quickly Makems. The door closed OK. There's a long rod top to bottom on the inside. The bottom of the door comes away (when pressing the knob) but the top is stuck fast.
If only I were inside CWH!
Thanks again.
MC 55 FUN
3,432
6,347
Rural South West Wales.
2015 Majestic 195
Since 20th Feb' 2016
Thanks again.
That push button lock is similar to the one on our wardrobe - I think they unscrew allowing access to the mechanism which controls the vertical locking rod.
G
Gemini
7
Taunton
Rapido
Thanks very much MH55FUN - I'll check to see if the button will pop out - perhaps I should find a locksmith in case I break the door.
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Lean hard on the topof the door and wigle the knob in and out it may just release the top hook. Why Rapido persist in using this door locking mechanism is beyond comprehension as they are a real load of rubbish.
I took the two long rods off and put a mangnetic catch on instead
G
Gemini
7
Taunton
Rapido
Thank you so much laneside, I'll have a go.
CWH
5,151
247,515
WildAx PVC
From November 2013
We have same mechanism on wardrobe doors, they get stuck sometimes when something falls against the little hook. Technician at dealers showed us how to lean against the offending area & it worked for us too. Horrid things. Wouldn't want them on an important door like a bathroom! :eek:
G
Gemini
7
Taunton
Rapido
Thank you for posting again CWH. You're right, always been unsatisfactory but I didn't know what to do. Perhaps a magnetic catch is the answer. Thanks again. I'm absolutely amazed at how helpful everyone's been.
