My van is a 2008 fiat Ducati based a classanyone got a recommendation for putting a better one instead of the abysmal one one my Autotrail Apache Fiat Ducato 2008 ( I believe the original is in the door mirror ?)
It was already fitted when I got the van I thought it was standardthat looks ok ,where did you get it?
There's only one really decent aerial position and type. There's no magic involved and no fancily-described alternative: that is as high as possible, of decent quality, and for some types, with the best ground plane you can arrange. Every other position and type is to conform with styling or ease of mounting. These days I'd mount a dual DAB / FM aerial on the roof (in fact l have). DAB with a decent aerial is brilliant more than 90% of the time - it's biggest advantage in a vehicle is seamless handover from one transmitter to the next with no fade or noise. But FM is there if needed for the few times DAB isn't available.
No (although you may hear otherwise). The best dual (DAB / FM) aerials have dual co-ax from the aerial base. There's no reason to buy a dual one if you will only ever need FM. But given the effort involved in running the coax from the aerial to the radio it's not a bad idea to future-proof.so will digital be ok for an FM only radio?
This is the one I used:so tonyidle any recommendations
That requires a permanent mobile data signal and costs mobile data.Alternatively change the head unit for a cheap Bluetooth unit off eBay and then run a radio app on your tablet or phone through the stereo.
£15 for the stereo off eBay and any radio station you want anywhere
I've never had a problem with it and uses little data . But it means I get any radio station I want crystal clearThat requires a permanent mobile data signal and costs mobile data.
