- Apr 15, 2022
- 177
- 247
- DethleffGlobetrotter
- Started in 2005, then took a 15 year break, back in 2022
We do the same with iPads and iPhones. Connections are just as good.One alternative would be to use the ‘Hotspot’ function on your mobile ‘phone.
Connections may be as good but the signal won’t be as if they are powering an antennaWe do the same with iPads and iPhones. Connections are just as good.
Will or can the Netgear connect to dual antennas when in the moho?My netgear m2 mifi runs off battery or usb at 5 volts, it will also work on usb if you take the battery out, so you don’t damage the battery.
It can also pull in a signal where our phones can’t at double the speed.
Which antenna was it (that was no good)? I don't really want to spend over £100 for an antenna that doesn't really improve the signal that much (as it's a pretty good signal already I've found)The M2 has 2 antenna ports, I purchased an antenna for it that made no difference what so ever, it was actually worse, so I sent it back.
I just put it on the dash or in the roof vent when in the van
This is the thing, price has gone up a bit.I use a buck converter with a USB output that turns off when the battery is charged to power my 5577.
Sorry I can't find a link at the moment, came from ebay.
