Powered Retractable step (1 Viewer)
Zipadedoda
South Hams, Devon
Burstner Lyseo TD727
Since 2022
Hi There. I have a 2022 Burtsner Lyseo TD727G. The powered habitation step has failed in the open position. Has anyone else had this problem? If yes, what was the solution?
68c
Oct 22, 2019
1,726
2,579
Southampton
2001 Pilote 270
Since 2004
Have a look around the step mechanism. Look to see if there are any connectors in the wiring that may have been covered in dirt. As most steps are behind the rear wheel they get covered in road dirt flung up by the wheel, you really do need a mud flap there. Be careful while wiggling things, a contact may be improved and the step suddenly retract, your fingers won't stop it.
Jan 8, 2013
8,400
11,387
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Have you tried helping it in with your foot?
It might only need lubricating.
Mar 6, 2021
65
78
Worcestershire
Dreamer D68 PVC
A little
I have had this issue and, oddly enough, it has happened to me again just a few days ago. I need to sort it out again as I need to take the van out. Last time, I removed the fuse from the fuse box thinking it had failed and was going to replace it but found that reseating it triggered the step into retracting. Hopefully it will work again. Frustrating.
Lenny HB
50,293
138,954
On the coast in West Sussex
Hymer B678 DL
Common problem with the steps is the nylon gear teeth breaking or stripping. Sometimes you can reposition the gear wheel as only a section of it is used.
Two on Tour
9,760
45,789
Elddis Autoquest 175
Since 2010
Lenny HB
50,293
138,954
Hymer B678 DL
Strange no one on my ignore list, viewing on my tablet, just tried phone the same. I'll have a look on the pc when I get up.
Oct 15, 2012
9,898
54,135
Market Harborough
C Class Laika Ecovip 7R
Hi and welcome to FUN. (y) As others have said, give it a good clean, then check the wiring, then spray everything.
Nov 3, 2020
1,178
2,045
Up the Hamble
Ace Siena
Since 2019
Had this problem (albeit on a much older moho) - turned out that removing the main fuse was the solution, it is a form of hard reset for the control panel. Worth a try before you start scrabbling around with the lubricating/penetrating spray of your choice etc . . . .
Mar 6, 2021
65
78
Worcestershire
Dreamer D68 PVC
A little
Just to confirm, I removed and re-seated the corresponding fuse and the step retracted okay - not immediately as I had my side door open but as soon as it was supposed to. Owners manual should tell you which fuse (yellow 20 amp) is the corresponding fuse.
Sep 28, 2021
42
51
West Lothian, UK
Burstner LyseoTD690G
Since 2019
I had this a few weeks ago. As another poster suggests a little help in with the foot was enough then when home added some lubricant and been fine since.
