Power Packs (1 Viewer)
Sep 13, 2017
119
76
Staffordshire Moorlands
Rapido Fiat MWB
I want to disconnect the engine battery on my Fiat Ducato 2.3 2015
As anyone used one of these successfully.?
If so what make did you buy and any comments/recommendations.
42,963
47,023
Any 12v battery and jump leads will do as long as its connected to a permanent live and earth before removing the battery.
Don't forget to insulate the main battery live wire when removed as the temporary battery will still make it live.
Same caution applies if you use a power pack.
Jul 29, 2013
8,866
16,134
Salisbury
Hymer B678DL A class
since 2011
I bought a Clarke’s power pack it wasn’t very expensive but does as required if needed I also use it to power the winch on the car trailer.:xThumb::xThumb::xThumb:
TheBig1
17,167
41,056
just remember fitting a temporary memory retaining battery pack is a very short term fix. designed to keep the memory settings for a few hours normally. you will need to keep charging it up, the same as the engine battery throughout any period when the van is stood idle
Apr 22, 2018
6,541
12,045
Herts.
Adria Coral lowline
I use my ctech charger as it has this as one of the settings, and then also does more than one job.
Deneb
1,598
2,334
Europe
PVC
I'd be wary of using a power saver or similar on a modern vehicle unless you are just changing the battery over. If you're doing any work on other systems, leaving power in the vehicle is a real risk of corrupting an ECU or could be dangerous if you're working on or disturbing the SRS system.
There's not much that needs resetting on current Ducatos. If you have the factory radio it will self reset without the need for a security code after communicating with the BCM as long as it is still in the same vehicle.
