My question was not about surviving it was more of an observation around long term Spanish running cookers, fridges, microwaves, toasters, bbq's etc. All of which are household appliances and not low power modelsWe manage no problem on 6amp supply when in Spain. Solar panel and refillable gas help.
You have to use them one by one I suppose, no other way. You can fit your own power meter to keep your eye on it, got one in the van, goes up to 10kw.My question was not about surviving it was more of an observation around long term Spanish running cookers, fridges, microwaves, toasters, bbq's etc. All of which are household appliances and not low power models
For example, if you have a Victron Multiplus 1600 inverter/charger, you can run up to 1600W while off-grid. A 6 amp mains hookup should be able to supply about 1400W.If you have a combination inverter/charger with mains backup you just set the incoming to say 5amps and then any heavier demand is inverted off your batteries which are then recharged over a longer period ready for the next big hit.
Still don't understand your point. Cooker: gas anyway, microwave: only on for a few minutes and uses just over 2 amps. Toaster: don't have one, use the grill in the cooker which is gas, bbq: gas of course, or charcoal. Fridge: very low power consumption or run it on gas.My question was not about surviving it was more of an observation around long term Spanish running cookers, fridges, microwaves, toasters, bbq's etc. All of which are household appliances and not low power models
