Drexel
hi im new to this forum but in one days membership have got advice and repaired/replaced 2 relay switches and now have a leisure battery that charges has it should when engine is running ,so time to try to solve 2nd problem on my very long list
i have a 1995 swift royale and the battery charger (PLUG IN SYSTEMS )isn't charging, it has mains power to it and switch on top of charger lights up but the red wire and white wire that leave it give very little volts ,at moment 4.6 and dropping ,it looks to me like the leisure battery when connected to the charger is sending power back into the charger because when i first disconnect the feed to the battery it reads what ever the battery is but starts dropping immediately.i have no experience with these chargers so my question is ,is it buggered or is there something i must do ,ive checked the fuse annd thats fine and working also i have a normal car battery charger that i will use if needed until i sort this problem and move onto my next on the list ,thanks in advance
