Peugeot eldiss autostratus wont start
Paulamg
Eldiss autostratus
Hi i have a 2002 peugeot eldiss autostratus. It will turn over but wont start. I have had an auto electrician remove the immobiliser as thought this was the problem but still wont stsrt. There is fuel going into the injectors so its not that.
Does anyone have any ideas??
I have 2000 Peugeot Autostratus with the 2.5 TD motor.
Had a no start problem twice, both times the culprit was the fuel filter. At the top of the filter is a rubber seal that split.
The RAC guy who came out the first time said fuel will still get through but not enough to start the motor as air gets sucked in past the split seal.
Not sure if this will help you but good luck finding the solution.
I havent tried that yet xan yiu use that on a 2002 model?
Thanks I've tried the easy start and it started tried to find fuel shut off switch to reset it, found a switch and pressed it above the battery not sure if this was reset button. Any ideas??
Hi Yes the fuel is coming through but not enough pressure possibly the same problem. Mine is turning over but not starting was this the same with yours
Sorry for the delay responding.
Yes, it just refused to start. Once the fuel filter was changed, it fired up after a few seconds. It has run perfectly since.
