Peugeot Boxer PVC 2016, how to change battery? (1 Viewer)
Jan 1, 2017
1,161
2,618
eastbourne
van conversion, Peug
4 years
Happy Christmas all, went outside to take the van for a run out after two flat battery ( vehicle) incidents this week. I use the van as a daily driver as well as a motorhome and it looks like the battery has had it .
opened the cover and wasn’t expecting all of those the wiring connections, (see photo)phew.sooooo, How do I change the battery, numpty question I know but I’ve no idea! What is that black plate with wiring all over it? The neg terminal is attached by a clip on to a ‘post’ .
I cant see a battery name type anywhere for a replacement but does anyone recognise it or can suggest a best replacement.?
Thanks in advance!👍
43,367
49,720
Loosen the nut at the bottom right of the pic on the Pos post being careful not to let the spanner touch and metal. .
Loosen the nut at an angle upwards on the Neg post.
Lifting both plates will reveal the disconnected battery... May need a bit of a twist to break free of the post and remove the Neg plate first... All the wires will remain connected to the clamps.
Secure both out of the way then lift out the battery after removing any hold-down fixings.
uzsnowdrop
Jan 1, 2017
1,161
2,618
eastbourne
4 years
So helpful , thanks, will get on it tomorrow now as the lights just gone ....merry christmas
uzsnowdrop
Jan 1, 2017
1,161
2,618
eastbourne
4 years
Wasn’t expecting to see all that on top!
Emmit
8,050
17,794
Pilote Explorateur
Jan.2014
The nut and threaded bolt that faces north south to the right of the photo above releases the positive side of the connectors from the terminal post on the battery.
Feb 8, 2014
1,663
4,682
Sheffield
Eldis Majestic 115
Vans and tugs since mid 70's
The pic below shows the receptor threaded holes for the +pos tray assembly at the left of the +pos terminal.
Oct 10, 2018
2,014
1,140
Bracklesham Bay, West Sussex
I was certain they screwed directly to the battery top?
That is how mine is with the two screws going through the red plastic into the casing, I think they are to support the multi-connector terminal plate. You need to remove them as well as loosening the terminal to be able to move the plate away from the battery .
Feb 8, 2014
1,663
4,682
Sheffield
Eldis Majestic 115
The nut and threaded bolt that faces north south to the right of the photo above releases the positive side of the connectors from the terminal post on the battery.View attachment 451280
Thanks Geoff C. - though I was going daft:xThumb:
uzsnowdrop
Jan 1, 2017
1,161
2,618
eastbourne
4 years
...so the black bar across the middle is just a bracket/brace right? Just undo it?
43,367
49,720
I really can't see that, it's compromising the battery case for one thing and it's not needed for another.
Think of the result if someone lost them and decided they only had 2 or 3 inch screws....
The battery clamp should keep everything in place
Oct 10, 2018
2,014
1,140
The battery case is not compromised as the holes for the screws are there, on the correct battery, for that purpose, the terminal plate has many connections going to it and although the clamp alone will hold it the screws are there to support it and stop it twisting. They are not live and only go through the red plastic piece to clamp the plate to the top of the battery.
Feb 8, 2014
1,663
4,682
Sheffield
Eldis Majestic 115
Hi pappajohn the last couple of replacement batteries that I have recently fitted required the removal of these locating screws. I do agree if longer screws are used then damage to the battery could ensue.
Feb 8, 2014
1,663
4,682
Sheffield
Eldis Majestic 115
Well, I stand corrected but why 2 screws? And why are the red plastic bits shaped as they are and overlapped when a single flat plastic strip or 2 washers would suffice
Or more beneficially just a locating lug as on many other sensible products?
Jul 10, 2018
245
519
Worcester(U.K)
Tamar Ducato160multi
If you have a cab radio that has a secure code have it to hand before you start
If your alarm has special instruction for resetting? either have the instructions or contact the supplier/installer
I encountered no problems and I had a residual voltage feeding back to the cab due to a Sterling BtoB being installed.
Be absolutely sure you have the correct replacement battery! physical size capacity and terminal configuration.
Remove the cab carpet and there is the floor panel with coin turn fixings a 50p piece is good, just half a turn on each
Now you have the battery box cover, just remove the two nearest 13mm bolts.
The lid hinges up and then pull it away from the hinges towards you.
This is what you will find
Now remove the battery clamp 13mm nut
Now disconnect the Negative clamp, no spanner needed here but best to remove the cable out of the way altogether by removing the 13mm bolt to the chassis also.
Now remove the terminal cover at the +ve end
Remove these two screws and the red plastic doobree lol
Then slacken the +ve clamp nut 10mm ring spanner and lift the lot clear
Pull out the old battery
Present the new one
Be sure to remove both transit plugs
Reverse the whole procedure Amen
EDIT this is a left hand drive vehicle so do not be confused by that.
uzsnowdrop
Jan 1, 2017
1,161
2,618
eastbourne
4 years
Also the negative terminal is normally quick release you don't need to undo the bolts just push the lever.
Found that when fitting new seat the other day... who knew? Great idea. Its a loooonnngg time since I changed a battery, vauxhall viva I think...🤔
32,695
66,727
If I'm doing anything with batteries, as I remove each of the cables I immediately tape it well out of the way with gaffer tape, no risk then of it moving or getting knocked onto the battery terminals etc.
