Passenger seat arm loose
Newbury
AS Kingham
Since 1970
A question for those who can’t find anything worth watching on tv, can’t even find the Great Escape. I have noticed that the arm on the passenger seat has quite a bit of side to side movement when compared to drivers seat. My guess is that a nut is coming loose and will only get worse. Second guess is that 90% of task will be accessing it. Am assuming this has occurred before so any advice would be greatly appreciated. Van is 2018 Peugeot Boxer. Thanks
Mine, although Ducato just needed tightening. Was simple so checked both arms, on both chairs. All needed a bit of tightening it appeared.
As above but there's also steel pin in the pivot that can get bent.
if it comes loose take the allen bolt out, add some thread lock to the first few threads and reassemble. Or it will only come loose again after a few uses of the arm
Thanks all. Merry Christmas
my burstner arm rests always needed adjusting. While in Spain i took one off to take home on the plane as it needed welding but when my bag was x rayed in Alicante airport it looked like a Kalashnicov and was taken to one side.
