Oyster Satellite problem (2 Viewers)
spitfire
2,408
5,135
Correze France
Bavaria
Since 2003
Stupidly did not watch battery level and tried to put dish down ! It did go down but not in the correct position. Just a bit squint to the correct place. have managed to get up on roof remove the rush and get it back to the correct position but now nothing !
Is showing 0001 on the read out .
Anybody got any ideas ?? Am in Portugal atm and as I live in France would prefer not to let the French get at it !!!
Nov 25, 2013
1,120
1,763
kent
Swift Kontiki 669
Since April 2013
You can reboot the system , but you need the operating instructions from the manual. I had problem with mine that turned out to be a PCB problem , New board cured it. Good luck.
spitfire
spitfire
2,408
5,135
Correze France
Bavaria
Since 2003
Thanks Martin . If it is a new board that us needed would you be prepared to give me an idea of the cost ! Remember I am scottish.
Hogan7777
76
138
Valencia, Spain
Hymer B 694SL
Since 1995
If it's a vision 3 hold all four buttons in when unit is in stand by mode. And or disconnect power for 5 mins.
spitfire
spitfire
2,408
5,135
Correze France
Bavaria
Since 2003
Thanks Hogan but isn't that new :-( it says Rs232 on the box . Looks fairly basic !!
spitfire
spitfire
2,408
5,135
Correze France
Bavaria
Since 2003
Switched off and on again ! Still the same !
18,038
48,155
rs 232 just means a serial connection, it is a standard. Is there not a model number?
Edit, a quick Google suggests you need to disconnect the power supply, for example by removing the in line fuse, if it has one. It should then reset itself. Not just turn it on and off.
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Not quite sure why unplugging the unit will not do the same as removing an inline fuse to the PSU, unless it has. An onboard battery
Hogan7777
76
138
Valencia, Spain
Hymer B 694SL
Since 1995
Lots of electronics need complete disconnection to allow any residual voltage to bleed off. It's no good just switching it off. That's why you have to unplug sky/ wifi routers etc when they get scrambled.
18,038
48,155
Unplugging would have the same effect, I thought you meant you had just turned it off with a button.
Oops, thought you were the OP! Unplug, cut the power lead with a knife, all should do the same thing but some methods will be easier to undo!
spitfire
spitfire
2,408
5,135
Correze France
Bavaria
Since 2003
Thanks folks for all the advice but still have a none working system :-( everything has been switched off , disconnected and even dismantled but no joy :-(
The dish is now on the ground beside the van. The motor and arm back on the van . Power to everything checked and there so guess it is knackered :-(
Might mean a visit to Germany on our return home cos sure as eggs is eggs a Frenchman is not touching it !
18,038
48,155
Hopefully it just needs a cuff around the ear from someone who knows where to hit it. Worst case something has burned out or been stripped. :(
Out with the Scrabble it is then.
spitfire
spitfire
2,408
5,135
Correze France
Bavaria
Since 2003
Hope it isn't too bad ! Might give Tenhaft a call in the morning !!
We bought a Humax Freesat box with hard drive so lots of crap on there to watch ! Can only get the news and pick tv in a Portugal so not missing much !!
Reactions: DBK
spitfire
spitfire
2,408
5,135
Correze France
Bavaria
Since 2003
Given it us Friday 13th thought it might be good luck and the satellite would have revived overnight but no :ROFLMAO:
Nov 3, 2013
3,172
9,395
Portugal
Fiat Ducato Auto Wildax
C/van since '73 .M/h.2009
Hi.
It does not........ "Wok then"..... still ?
SORRY, could not help it... (Write out one hundred times Don't take the wee wee LOL)
Tea Bag
