outside shower (1 Viewer)
roger
13
littlehampton sussex
c class
8 years
Went away to the CC site at Brighton this weekend, but when I started to pump the water through to pressurize the system, water started to come gushing out of the outside shower connection, had a good fiddle with it pushing the valve in ect, seems plenty of pressure but couldn’t stop the water coming out. In the end left the hose and showerhead connected all weekend. It looks like that I need to source another valve. It’s the standard rapido outside shower .Any info would be much appreciated.
23,836
72,511
Roger, got to ask.. Did you leave the tap closed during the icy periods ?
If so then yup.. new one will be on the shopping list for you :Sad:
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Hi not sure what the valve is but if you ring my lot I am sure they will know.
Peter
Robinhood
158
Sherwood Forest
20 years
Had the same issue with my Rapido on preparing to go away at Feb half-term.
The outlet 'wept' water under pressure, and I couldn't stop it.
When I looked into the outlet, there was an 'O' ring which had been slightly displaced (pushed forward in one quadrant -presumably by a little bit of residual water forming ice in the very cold weather).
It wasn't sealing, and there was no way I could get it to re-seat fully circular by pushing it in (the valve is spring loaded and makes it virtually impossible to put a ring in from the front.)
(Incidentally, neither could I stop it leaking by leaving the shower in - so things might be slightly different from your issue - but the dismantling info should help.)
Looking at the head of the outlet, it is hex shaped to take a socket/spanner. I came to the conclusion it should dismantle for detective work, but on putting gentle pressure on with a socket, I wasn't convinced that the pipework wasn't moving, so I stopped.
After dismantling the van interior to get to the back of the pipework, I discovered that I was unlikely to damage anything unless I put an inordinate amount of force on the socket - so I tried again.
This time, the outlet head unscrewed, and I could get at and dismantle the valve. The 'O' ring, having been pulled out earlier, was then reinserted from the rear of the outlet (against a small retaining lip) and everything re-assembled. Success! (all this from outside the unit)
The single 'O' ring completes the valve seal (the valve face being brass and thus needing something to butt up to), and also forms the seal with the shower unit when it is inserted - the 'male' plug being shaped to engage with the outer face of the 'O' ring and push the valve back.
The retaining lip is very shallow, so I'm quite surprised I've not had problems before. I'm thinking of lining the cover with polystyrene before next winter.
Hope this helps - the offending 'O' ring is easily visible by looking into the outlet, even when it is properly seated. I would suspect some issue in this area. (My external shower unit is the one that doesn't have on/off - the valve accomplishes that - and a single temperature tap - I think Rapido are still using it so yours is probably the same).
roger
roger
13
c class
8 years
Thanks for the very helpfull info -as soon as its gets a bit warmer I will check it out.
Best wishes
Roger
