It's looking good.
It been a bit harder work than I expectedIt's looking good.
You must be chuffed to mint balls with thatIt been a bit harder work than I expected
WB
Every thing on this forum seems to go without any problems i showing everything warts and allIt's looking good.
Tomorrow I have to get the balls to cut the hole in the roof I am only cutting 24”x24” hatch in the roofYou must be chuffed to mint balls with thatvery brave to cut a whopping great hole in a van roof
Then I can start the wiring and insulation of the van
Still a long ways to go but hopefully will be sorted by the Christmas but if not the spring
WB
Is there anything to pull the canvas inwards when it closes?View attachment 1093146
It’s working yippee
Yes it has hinged pole things but will be watching it like a hawkIs there anything to pull the canvas inwards when it closes?
You won't want to trap it under the roof.
Where is your panel located? On the new elevating roof?. Not much space left of the original roof plus a danger of shadowing etc with the pop up.?Just ordered 10 m of soler wire for the soler panel
I have 420 watt panel charging 280 amp deep cycle battery
We will also have 3000w inverted she who cooks wants a microwave.
Will have lots of usb sockets all over the van
230/40 power for when were on EHU or sunny days
Really enjoying this build
WB
My van lights have a + ve and - ve.So rather than run a lot of black negative wire could I use the body of the van as negative or am I better running a negative wire to each
Light 12v appliance?
Might be a stupid question looking forward to to some interesting answers
WB
It going on the pop up going to put additional gas struts to assist itWhere is your panel located? On the new elevating roof?. Not much space left of the original roof plus a danger of shadowing etc with the pop up.?
I have ordered a five gang fused usb and lightning switch PanilesMy van lights have a + ve and - ve.![]()
You still have to connect the - ve light terminal to the body. It's easier surely to use 2 core wireing. It's not expensive.( and less prone to poor connections)?I have ordered a five gang fused usb and lightning switch Paniles
So each light is led but will have an independent fuse and switch.
I am also having usb in dinner aria boath sleeping arias and kitchen
But thinking I can use the body of the van as common earth?
WB
Ok that will be the way to go I think.You still have to connect the - ve light terminal to the body. It's easier surely to use 2 core wireing. It's not expensive.( and less prone to poor connections)?
Yes was thinking that just after I posted itYou still have to connect the - ve light terminal to the body. It's easier surely to use 2 core wireing. It's not expensive.( and less prone to poor connections)?
I have ordered 25m of 12v black and redYou still have to connect the - ve light terminal to the body. It's easier surely to use 2 core wireing. It's not expensive.( and less prone to poor connections)?
I am doing a bit on the boat not much as I am putting it up for sale in the springYou're doing a good job there, Bill, for someone taking things easy.
What's happened to the boat?
No it got two inches of insulationDid you fit any sound deadening to the roof first?
