Onboard charger output. (1 Viewer)
Mar 30, 2019
2,776
5,145
Cardiff, UK
Since 2016
How can I determine the output of my onboard charger? . I do have a multimeter 🙂
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
The multimeter will tell you the volts on your charger output. However, that tells you only so much (although this might be enough depending on why you are asking). To tell amps, you will need some sort of shunt (an accurate low resistance device in line with the battery) to measure the voltage across that. Your multimeter might have such a 10A device built it, but it would be hairy to use it safely and it is one of those "if you need to ask" type questions.
Jan 19, 2014
9,390
24,772
Derbyshire
Elddis Accordo 105
since 2014
Set the multimeter to volts DC and put the probes on the battery terminals. Sometimes the onboard charger is just a 13.8v power supply like our Elddis one was. To see what it's up to you've either got to watch it or get it's user manual.. Or Google it 👍
Itsmcb
Mar 30, 2019
2,776
5,145
Cardiff, UK
Since 2016
The the make and model number and I'm sure one of us on here will find the info.
It's in a 96 Kontiki 640. Built into the power supply unit in the wardrobe. No labels at all sadly. Everything is working fine, I am thinking of adding a second 110 amp leisure battery and was just curious how quickly (or slowly) it might charge them.
Jul 6, 2009
1,796
2,221
It’s 10 amp at 13.8 volts. It will really struggle to keep on top of 2 x 110 amp batteries. Depending on. How much demand. Rule of thumb min unit capable of charging at 10% of capacity
53,430
149,981
If it is that type the Batteries will never get a full charge and will only last a couple of years. If you want your batteries to last you need to replace it with a decent multi stage cgarger.
Itsmcb
Mar 30, 2019
2,776
5,145
Cardiff, UK
Since 2016
I do have 270 watts of solar on the roof so during the summer I think the battery gets fully charged from that. I want to add a second battery to give more reserve through the winter. Can I add a second freestanding charger to use through the winter without disconnecting the existing one?
53,430
149,981
You would be better disconnecting the existing one as it is not doing your batteries any good.
If your current battery is much more than a year old you need to replace that as well when adding the second one.
17,630
43,277
if I recall correctly, there is a switch to turn the built in charger on/off. If you install an updated charger, remove the fuse for the built in one. Otherwise the new charger will see the constant 13.8v put out by the old one and assume the battery is fully charged
Jan 19, 2014
9,390
24,772
Derbyshire
Elddis Accordo 105
since 2014
I removed our old charger completely. It's left a nice slot in the top of the fuse box for the mini socket set and clamp meter 😎
Tombola
4,831
15,709
Merseyside
Rapido 8094DF
Im in a similar boat. I am thinking of remmoving the old 10a charger in the sergant control panel and addingt he Victron30 amp multistage somewhere.
My question is if I find the exisiting output cables from the old 10a would the cables from that to the batteries which I am (upgrading to lithium 200a) be ok to take the new current.
John
53,430
149,981
Im in a similar boat. I am thinking of remmoving the od 10a charger in the sergant control panel and addingt he Victron30 amp multistage somewhere.
John
Not in an Autotrail, cables are way under size for the existing install.
17,630
43,277
just mount the new charger nearer the batteries and run an over specced cable between them
Itsmcb
Mar 30, 2019
2,776
5,145
Cardiff, UK
Since 2016
Ah, yes there is a switch on the top of the box👍. I can just turn it off, then I would have a back up if the new charger failed for any reason.
Itsmcb
Mar 30, 2019
2,776
5,145
Cardiff, UK
Since 2016
I have a single 230v socket in the locker near my battery (ies). Can anyone recommend a suitable charger ?
