Hi to all. This post relates to a problem I had with my motorhome fridge. On board I have a Dometic RMD8555 fridge/freezer. The problem I had was that I was unable to turn the fridge off via the front display control panel or change it manually, it was stuck on gas. Unfortunately it appeared that Dometic no longer supply either the main pcb at the back of the fridge or the display pcb on the front of the fridge. However I did find an electronics company that do manufacture replacement boards. This company is called Apuljack Electronics Ltd of East Brent, Somerset. Having spoken to one of their Tech guys it was thought that the problem was probably the main pcb at the back of the fridge. So board purchased and easily fitted by myself but although some functions working fridge still would not turn off or manually switch to gas, 230 or 12 v. It did however hunt for the best supply on AES. So I bit the bullet and purchased the display pcb. Now this board has the power ribbon, which runs to the main board. soldered to the display board but Apuljack has come up with a joiner which you fix to the ribbon(16wires in ribbon) which you cut off the display board. So you dont have to remove fridge or replace ribbon. Both connected and fridge now working. Cost of these boards about a third of the price of a new fridge. If you got my problem worth looking at Apuljack. Sorry long winded.
