Had the same problem with mine last week and the plug had worked it’s way loose out of the charger/distribution board was in a silly place underneath pushed back in all goodI am parked on my driveway, I have just tried to hook up but I am getting no 240 power in the van I have checked all the leads , but there is nothing showing in side.
van is a Rapido 9048,
Could be, but it could be damp in somewhere causing a slight earth leak. Unplug the van lead and Measure resistance between earth and live pins, should be infinite.After flicking the switches & pushing the test button on the breaker a few times the electrics came back on, could the breaker be on the way out?
I would be inclined to check the plugs, either first or as well. It is not unknown over time for the connectors to come loose. And even, in my case, not having been properly made in the first place!Could be, but it could be damp in somewhere causing a slight earth leak. Unplug the van lead and Measure resistance between earth and live pins, should be infinite.
Little point in doing this with a normal multimeter, you have to use a special meter that uses a high voltage to check the resistance.Could be, but it could be damp in somewhere causing a slight earth leak. Unplug the van lead and Measure resistance between earth and live pins, should be infinite.
Yes I didn't figure he'd have a 500v insulation tester. Sometimes it shows up on a multimeter though, it'll show up as many millions of ohms on a multimeter but rest assured it's a fail ?Little point in doing this with a normal multimeter, you have to use a special meter that uses a high voltage to check the resistance.
