Well here is tonight's effort to tell you all about the water tank in my van, this post will be a very short one as the pictures will tell a better story.
As I have read and watched many, many videos on the pros and cons of an inside or a under the van water tank we (I) decided that the water tank would be best placed inside the van, under the bed, in actual fact the tank will act as a support for one side of the bed.
I have mentioned in one of my earlier posts that in my younger years I was a fabricator / welder so it made sense to me to make a bespoke water tank which can be fitted over the drivers side rear wheel arch. (Especially after looking at the prices for a plastic one)
The tank is made from 2mm thk 316L stainless steel and holds 118 litres of water when full, it took me just one day to fabricate from sheet steel including the welding. (It was a very long day)
The next day was welding on 1 x inlet pipe and the 2 x level gauge nozzles, 1 x drain nozzle, 1 x outlet nozzle and obviously a static leak test.
I had brought ALL the items that are connected to the tank to supply both the cold water and hot water system, these are not yet fully connected as my combi boiler has not yet been installed.
One Question I would like someone to answer is.. I have brought a Shurflo 2095-204-413 Trail King 7 Water Pump-12V/30psi and when i came to fit it I had to install with it in the horizontal position, is it possible to turn the body around on these pumps so the fixing brackets are 180 degrees to how it is when purchased.
Please see the photos and please advise regarding my PUMP QUESTION, thanks in advance.
