Here is our take on a self conversion, crafter based.
So, here we are, two months with some longish days in between, and a lighter wallet after, that is our result. Main time consuming( 1/3) was the insulation and vapour barrier seal. The rest was just straight forward, with the odd detail work that required some extra care.
The most expensive, was energy storage (400ah LiFePo4) storing 5kwh, followed by appliances, solar system and inverter charger. The panels we chose are Panasonic hybrid, that are a smidge more efficient in dull weather and the size. They the only panel that fit across and not stick out over the gutter edge. Most others fairly priced, except moorland board at ÂŁ139 a sheet. We went for the high pressure laminate, which is quite different to the normal furniture boar. Some things we might change in time, like cushion covers, curtains and I'm going to make my own thermal windscreen covers. At the moment we get by with a black out curtain to the cab area. I have insulated over the cab fairly well, but some condensation still needs looking in to. We use the max fan quite a lot, specially when cooking, washing etc. I'm looking at a possibility to incorporate a humidistat somehow to turn on the fan on exhaust during wet seasons.
I think you have done a great job so far. A friend of mine has done his own van conversion based on a sprinter with the same layout as yours. He had a problem with his kitchen window. His is top hinged and unfortunately when he opened his sliding door the door caught the window. He changed the window to a sliding opening to prevent any future damage.
Being retired it’s tempting to convert a van myself but being out most of the year with our current motorhome I just don’t think I have the time.
Lovely job, would have been my choice had I had 20k spare rather than 2k!!!
How wide is it internally?
Did you go auto or manual.
It's a proper auto rather than dsg apparently.
Are they can like or much more civilized like the transporter?
Cheers James
It came back van with windows last year. Adrian flux are not interested a bit, I got great cover with them.Yep good job... you must be well chuffed.. just one question.
Is it a Motor Caravan or Van With Windows. i.e what did DVLA make of it ???
Wonderful account of a build.
I agree about insulation, it's the parts that you cannot see that are the most important, no manufactured PVC will have the same man hours and time/money spent on insulation as yours.
Is it MWB just less than 6 metres?
looks good only thing i can never understand is insulating the van for warmth and then putting cold single glazed windows in
