Autocaravana cai ao Tejo em Lisboa. Condutor salta em andamento. Veja as imagens
Viatura pertence a um casal espanhol.
www.cmjornal.pt
He felt the need...... the need for speed!How did it get so far from the quay?
What do you suggest ? An anchor ?Could be the handbrake failed. Many people just stick the handbrake on and rely for their life/property on a single stranded bit of cable not breaking. US automatic owners are notorious for putting it in park and not putting the handbrake on, relying on a flimsy 5mm parking "pawl" not to break.
Not all vehicle handbrakes are equal ... Fiat ones are notorious for not holding well on slopes.What do you suggest ? An anchor ?
Every vehicle relies on a handbrake
So the driver jumped before it went in the water and left 2 adults and 2 kids in the van?Google translated.
"According to Correio da Manhã, the cause of the accident will be a technical problem with the brakes. The 43-year-old driver jumped on the road and suffered abrasions. He was referred to the hospital for hypothermia.
The alert occurred at about 11:13 am. On site were 12 operational and three vehicles from Firefighters Sapadores de Lisboa. According to information advanced to the CM by the authorities, the PSP identified the owners of the vehicle, who were monitoring the removal of the vehicle from the water.
The vehicle belongs to a Spanish couple. Two more adults and two children followed on board."
I believe if you put a automatic in park it locks up the gearbox so the wheels will not turn. However if you leave the vehicle in neutral the wheels will turn. Therefore Park is the safest if the handbrake fails.Could be the handbrake failed. Many people just stick the handbrake on and rely for their life/property on a single stranded bit of cable not breaking. US automatic owners are notorious for putting it in park and not putting the handbrake on, relying on a flimsy 5mm parking "pawl" not to break.
I see what you mean. So a thin bit of wire and a small bit of metal and parking on a hill is a insurance claim waiting to happen I have seen Videos of American cars that can slip into reverse when they are parked with the engine running. Not an unusual occurrence apparently.I mean americans tend to use Park, but don't apply the handbrake. "Park" relies on a tiny piece of metal called a "pawl" that can snap, just like a handbrake cable can snap. You should never leave a parked vehicle without TWO methods of securing it from running away. If a cable/pawl snaps and the vehicle runs away, I call that driver error.
Relying solely on Park is easily done, but lazy. I agree with your comment. A third safety precaution is a brick or rock behind a wheel. Used to be called the African Handbrake in pre-PC days.
The other hazard with the Ducato handbrake is the dreaded clothing malfunction when the lever snags your shorts as you exit the driver's door. Riiiip!
As you know, many modern cars (even Fiats) replace the traditional handbrake lever with a tiny switch for the electronic parking brake. There's a faint whirr from the electric brake motor and you have to put your faith in the unseen gubbins. It takes a bit of getting used to.
Despite the damage to my shorts, I'm hoping that this innovation won't be found in the next generation Ducato.
If you wish to see bricks and rocks under wheels go to West Africa where every truck driver there is uses them not as a back up but because the brakes on West African trucks are notoriously feeble due to lack of maintenance. Red Triangle? Forget it, but look for a line of branches on the road. Hazard lights, you should be so lucky as often they do not have any lights! A friend on mine whose car I was in heard me comment about a car we were in following another with no lights to which his response was, neither have I got any lights. A very common cause of death while working in Africa is running into a stationary vehicle at night parked in the middle of the road broken down unlit. Some friends of ours were killed that way. The result Isis you must drive at night be ultra cautious so we would only drive in the the town we lived in at night but never on the open road in the countryside.Relying solely on Park is easily done, but lazy. I agree with your comment. A third safety precaution is a brick or rock behind a wheel. Used to be called the African Handbrake in pre-PC days.
That sounds like he was trying to drown them to me
Getting the Fiat Handbrake to a condition where it will pass an MOT, is more art than engineering. There is a specific sequence to it. It took myself and my MOT test guy over 30 min to get the adjustment to a point where he would give it a Pass. And that was after fitting new brake shoes and thoroughly cleaning the hubs, and running it for some miles using the handbrake to get in bedded in!.Relying solely on Park is easily done, but lazy. I agree with your comment. A third safety precaution is a brick or rock behind a wheel. Used to be called the African Handbrake in pre-PC days.
