Motorhome Camper tyres versus Van tyres (2 Viewers)
KeefieWeefie
136
80
Bessacarr 520
Hi everyone. Just took motorhome in for service and repair. The repair shop just called to tell me that my newly installed Michelin Agilis Cross Climate tyres are illegal because they are not dedicated Camper tyres! They are 215/70 R15 with 190 load rating. This equates to 1030 kg per tyre or 1.030 Metric Tons. My Bessacarr is max 3.5 MT. Are the repair peeps mistaken? Obviously I've done loads of googling on the subject but you always get mixed feelings. Any thoughts would be gratefully appreciated folks!
May 7, 2016
7,268
11,765
West Sussex
Since 2003
“Illegal“ sounds a bit strong, what are your plated axle weights?
May 23, 2008
2,481
3,483
Near Durham City
Carthago
Since 1984
I've had two sets of Michelin tyres shred. Both were less than 3 years old and 11,000 miles. Changed to Hankook last year and they are brilliant.
One of my customer's looks after a fleet of 38 vans and will not use Michelin tyres now.
They've had endless problems with the walls cracking as mine did.
Choice is up to the buyer but named brands don't necessarily mean quality these days.
Simon Select
MH Trader
1,317
7,518
Devon
A Class Coachbuilt
25 Years
I could be wrong on this and I am not part of our aftersales department but I had assumed it was just car or commercial tyres? I presume they offered you a solution if you got your wallet out?
53,511
150,373
They are talking BS, providing the load rating is correct.
However, it is always advisable if not using CP tyres to have at least a 10% load margin. I assume you have a 2000 kg load rating on the rear axle so it would have been better to fit tyres with a 111 load index.
filopastry
1,016
1,738
london
littleun
newbie and learning every day
If they do not conform with the original tyres specified by the manufacturer .. beware. Subject discussed to the n'th degree on other threads.
phil
KeefieWeefie
KeefieWeefie
136
80
Bessacarr 520
I have no idea what plated axle weights mean but I do intend to take the van to a public weigh bridge to see what the actual weight over each axle is for tyre pressure adjustment.
KeefieWeefie
KeefieWeefie
136
80
Bessacarr 520
Thanks for the advice but that doesn't answer my question!
KeefieWeefie
KeefieWeefie
136
80
Bessacarr 520
Again my question was are the tyres legal or not!
Thanks for your advice, I will check what the weight is over each axle.
AXO66
762
4,715
Pembrokeshire
Chasson 510
Our Chausson arrived new with van tyres.
Goodyear Marathon
235/65R 16C. 115/113.
so not illegal not to have campervan tyres.
ps still ok after 20k, miles, just swopped front to back.
19,389
30,419
You will have a weight plate possibly in the door footwell, it will have gross weight which you say is 3500kg and maximum allowed axle weights which must not be exceeded as well as the gross.
I wouldn't worry about them not being camping but I would want the original load rating or better.
EDIT I should really have said it could well be your insurance who want the original load rating or better.
53,511
150,373
I think they are talking rubbish. Ask them to find you an alternative cross climate or 4 season CP rated tyre, or even winter CP tyres. See what they come up with!
Exactly using their logic you would not be able to drive your van in Germany and quite a lot of other countries in the winter where it is a legal requirement to have winter tyres.
53,511
150,373
Your van will have 2 or 3 plates on it, one for the base vehicle i.e Fiat, if it has an Al-Ko chassis it will have an Al-Ko one and finally the converters one i.e. Swift. The last one fitted is the one that counts i.e. Swift.
A typical weight plate;-
1st line is the MAM Max Authorised Mass (max gross weight).
2nd line Gross Train weight ( Goss weight + Trailer).
3rd line Front Axle max.
4th line Rear axle max.
AXO66
762
4,715
Pembrokeshire
Chasson 510
plated axle weight.
picture of ours
picture o
top line , max weight vehicle can be ( goodness knows why its 3550kg)
line 2 max weight of vehicle plus trailer , i believe.
line 3 max weight allowed on the front axle
line 4 max weight allowed on back axle.
ours is found inside passenger door frame.
(and there is the chausson plate showing max weight of 3500kgs, which is the legal one for driving license and weights on bridges and speed limits etc.)
hope this helps explain the axle weight plate.
53,511
150,373
plated axle weight.
picture of ours
View attachment 361260picture o
That one is irrelevant as the Chausson one supersedes it
May 7, 2016
7,268
11,765
West Sussex
Since 2003
I suspect that the tyre specifications have to be sufficient to exceed the plated axle weights rather than the actual weights from a weigh bridge.
AXO66
762
4,715
Pembrokeshire
Chasson 510
yep i know, and now you have me thinking.
the one i put up here has the axle weights.
chausson one has just the 3500 , and i do not recall it having any axle weights on it. Otherwise i would have saved a photo of that plate for future reference.
(motorhome is not parked on our property so can’t have a look now).
53,511
150,373
On the Ford plate the MAM/Gross looks odd 3550 kg would mean you need a C1 to drive.
What does it say on your certificate of Conformity?
AXO66
762
4,715
Pembrokeshire
Chasson 510
think that’s right and makes sense.
our load rating for single wheel is 115 which equates to a max load of each tyre of 1215kgs.
so 2 tyres can support 2430 kgs and our rear axle max plated load is 2200kgs.
AXO66
762
4,715
Pembrokeshire
Chasson 510
Thanks for the question.
Just checked, certificate of confirmity is clear, max permissable laden is 3500.
so why is the ford plate 3550? Which i have allways thought strange, especially with the combined weight of the axles being 4100 kgs.
Only thing i can think of is some structural factor around the joining of the motorhome part of the chassis to the ford cab . I.e. it’s not the standard ford transit chassis?
Chausson do buy a lot of ford transits and advertise it as having an extra wide section at the back to take the habitation body . And a wider rear axle track at the rear as well.
aria
138
218
Kincardineshire.
Apache 700
They are talking complete scribble. Once your tyres are rated above the axle load they’re fine. I uprated my rear axle and can’t even get camper tyres for the increased load rating.
Feb 26, 2012
528
368
coach
Motorhome since 2006 (caravanning 38yrs)
It is quite usual for the combined weight of the axles to be greater than the plated max. But you must not over load each axle beyond its plated weight.
KeefieWeefie
KeefieWeefie
136
80
Bessacarr 520
So if my plates real axle weight is 2,000kg and my tyres are rated 1,030 kg they must be legal? Or not?
JockandRita
11,470
150,356
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Legal.
What was the load index of the original tyres on that same axle, before you replaced them? As pointed out above, replacement tyres need not be Camper (CP) tyres, however, they need to be the same load rating for that axle, or higher.
In conclusion, I agree, those in the repair shop are talking out there ar$es. :doh:
Many MHs come out of the factory with C (commercial) rather than CP (camper) tyres on them.
Cheers,
Jock. :)
PeteH
6,853
9,032
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Some Sizes, are not even available in CP profile anyway. And where they are are difficult to come by.
Eg; Mine are R235/65-R16, And as far as I am aware, currently they are in limited supply from major manufacturers, and from some not at all.
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
If it was me.... I'd get written confirmation from my insurers.. as they would ultimately have the final say if a claim followed a tyre issue...
M-J
Jan 15, 2019
2,626
6,281
Cambridgeshire, UK
Rapido 986F
Getting there!
I always thought camper tyres were just van tyres that have more sidewall protection to help with staying still for longer periods?
My local tyre place is the largest in the area and been going for years has told me that when it’s comes to change, van tyres with the correct load rating will be fine and cheaper.
Nov 22, 2018
1,804
15,260
South East but not London
Rimor Europeo 87
Five years plus three tugging
Don't understand this thread!
The alternative to not fitting appropriate tyres is at the very least, an increased chance of a tyre failure, when you are trying to get somewhere. The very worst is an increased chance or wiping out your van and the occupants. If my handbook says I need a minimum of 800 kg per wheel, my paranoia orders me to go for 1200kg or higher!!
A cheap van tyre is a bit less than 100 quid. A tyre designed for a motorhome can be north of 150 quid. Total difference for four tyres is therefore about £200. My family is worth more than that!!
My question isn't whether, on balance, a moho or van tyre is a better idea - to me, it's bloody obvious. I would like to know funsters opinion on which motorhome tyre, best balances value with overall safety on the road.
I'm 225 75 16" Ducato Maxi 3800mm, 3500kg.
