Lenny HB
- Oct 18, 2007
- 52,710
- 147,676
- Hymer B678 DL
The outlet and filler are separate connections in the tank/bottle. It is recommended to turn the regulator off to avoid damage to the regulator as the filling pressure is around 140 psi. Truma regulators have an inlet pressure rating of 230psi so should take it but not worth the risk with regulators costing £200.I have an under slung tank so don’t need to open anything to fill up .
Can you explain to me just out of interest how closing the cylinder before filling works please?
It sounds to me that if the cylinder valve is closed then no new LPG can’t get into said cylinder. Is this the case? If it is how does the gas get past the closed valve?
Like I said, to me closing the valve then trying to fill is contrary to how I think a valve works.
