That's my setup been away for over 4 weeks 3½ in Spain used 85 GB so far.Hi ..I've got a e5577c huawei mifi.with superdrug sim
Worked OK in UK but in spain not at all. Just getting profile management error.
Help please
I've used Vodaphone a bit of a pain to set up but once working no problems.We didn’t find the above listed problems. Superdrug mobile worked faultlessly for us all over France needed no fiddling always staying on admin (which I can’t see the supplier altering). Much better than the Vodafone we’ve just binned for it, including it’s speed.
Yes but if you have previously roamed with other sims it should be on.Do yo have to turn roaming on.
Like I said Three network is always a pain but once you get on top of it it's works even if a bit slow.Ours has never worked properly. We piggy back onto our phones.
Lenny,Like I said Three network is always a pain but once you get on top of it it's works even if a bit slow.
Found the unlimited data useful now all the catchup apps stream live TV.
I player, itv hub, 4, my5, all the normal ones.Lenny,
What are the main catch-up apps you use whilst abroad?
Also been using Netflix & Prime.
If you have a UK sim they just work as normal when abroad.We can‘t get them outside the UK on our iPads or phones.
How are you trying to access them? Site WiFi or data from your phone using a UK sim?We can‘t get them outside the UK on our iPads or phones.
Haven’t got a TV in the van, so no Amazon Firestick. Have no idea how to set up a VPN, so we’ll stick with downloads before we leave the UK……and books.
Latest attempts have been all UK sims. Smarty in the van MiFi, Three in both our mobile phones.How are you trying to access them? Site WiFi or data from your phone using a UK sim?
WiFi you pick up abroad will not allow access. You need data via a UK sim or go down the vpn route which can be a pain.
Don't know what you are doing them they have been working fine with UK sims for about the last 3 years.Nope. Never been able to get them working in Cyprus, Germany, France or Spain. BBC iplayer and ITV Hub states we can’t use it outside the UK, when trying to login.
That’s having contracts with Tesco, EE and Three at different times.
‘Don’t know what I’m doing’?……..Spot on.Don't know what you are doing them they have been working fine with UK sims for about the last 3 years.
I've use EE (Plus net sim) , Vodafone, Three and now Superdrug (on Three).
But if you are using a UK sim to their server you appear to be in the UK.There you go………I’m not going mad. We download stuff to my iPad, before leaving the UK, but that’s it.
Definitely 3 x UK (and activated in the UK) SIM cards. I’ll be buggered if I know what’s going on.But if you are using a UK sim to their server you appear to be in the UK.
We are watching the Repair Shop on BBC 1 on iplayer in Spain at the moment using a Superdrug sim.
Something not right it should just work.Definitely 3 x UK (and activated in the UK) SIM cards. I’ll be buggered if I know what’s going on.
Tried logging on through the Smarty MiFi, and by setting up both of our phones (on Three contracts) as Hotspots……same result every time…..You’re abroad, you can’t use this service.
Great program by the way.
Are you abroad now?Definitely 3 x UK (and activated in the UK) SIM cards. I’ll be buggered if I know what’s going on.
Exactly what we do, but no UK TV apps will work abroad.Are you abroad now?
If you are, with one of the phones that the iPlayer app is installed on.
Turn off WiFi, turn on data and roaming and make sure it's working ( connect to internet).
Start iPlayer app. It should connect.
