Microwave installation Requirements
ChrisA1
Iveco Daily
I'ma newbie
Can someone let me know please what the DVLA expect in terms of installing a Microwave when changing the V5. I have young children so this is something we need and i have read the DVLA see it as an acceptable cooking method but didnt know if it can be say in a cupboard when driving then got out and placed on the worktop when parked up...or if it needs to be out permanently and fixed somehow? Thanks
A quick snippett from .Gov website
Cooking facilities
Cooking facilities must:
  • be an integral part of the vehicle living accommodation and mounted independently of other items
  • be secured to the vehicle floor and / or side wall
  • be secured as a permanent feature - bolted, riveted, screwed, or welded
  • consist of a minimum of a 2 ring cooking facility or a microwave in either case having a fuel / power source
If the cooking facility is fuelled by gas having a remote fuel supply:
  • the fuel supply pipe must be permanently secured to the vehicle structure
  • the fuel reservoir must be secured in a storage cupboard or the reservoir secured to the vehicle structure
Thanks. Yes I did read that but thought it was very vague about the Microwave bit, so wondered what others had done
In our old van the microwave lived in the bottom of the wardrobe and was taken out when needed and put back when done.
No, no burner. I have actually rang them today to get some details and they tell me it's fine for it to be just got out as and when required, as long as it goes on a safe secured basis/area at that point. We'll see however if that's still the case when I submit the paperwork to them...:unsure:
We installed a microwave into the division formally for a TV,( up high) between the kitchen and the bedroom. Its at 90 degs to the sidewall and not fitted to it and therefore wouldn't comply with the Regs. imposed by the Gov. site. (ie fitted to floor or sidewall.) We do however have all the other cooking facilities anyway. I bring this to anyones intention as I wouldn't want them to fit a M/W thinking that to do what we have done without having the other kitchenalia would be sufficient.
to be sure of getting campervan status i would show the microwave fixed to something either on a worktop with angle brackets or intergated into a cupboard
ps the brackets only need to look like they are fixed
Would it be possible to fix it in a suitable position in the cupboard, then when you want to use it just open the cupboard door? This would save having to get it out each time you want to use it and leave your work surface free. So long as it was safe to access it and usable (air gap etc) then I should think this would solve the issue.
That's how we have ours except we took the cupboard door off to allow for more ventilation.
Make sure that you have enough battery power to cope if you have a 12v microwave. Ours is a 240v for use on hook up only as we have a 3 burner hob and slow cooker in addition to the microwave. the slow cooker is also 240v but runs from an invertor if necessary. Don't do as I do (!) - I use the slow cooker when on the move as it is just the right size to go into the sink. We don't have an oven, at first I was dubious as to if we would be okay without but I've never missed it. If we really want roast chicken we can buy one ready roasted!
Its an interesting question, as to comply to the letter of the rules it must be fixed in place and have a fuel source connected.
Just replace a cupboard with the microwave, which can be used as a cupboard when travelling.
Install enough batteries, solar to charge and a big inverter to run the microwave
Much easier and cheaper to install a 2 burner hob with a dumpy gas bottle in the cupboard below. Not forgetting to add the require drop vent and clip the pipe to the wall
Your issue is not what is advised on the phone, but the untrained office temp that checks your photos against the requirements at DVLA when you apply to change the V5.
If it was in a cupboard or pushed back against a wall they couldn't see if it was fixed or not.
In my opinion the op is worrying about nothing
