Michelin tyres (1 Viewer)
Douglas
2,835
400
South Wales,
Due to Michelin no longer producing the XC camping tyres I have to change over to the MICHELIN AGILIS CAMPING 8PR 225/70 R15 112Q.
Unfortunatly I cant find the maximum pressure for this tyre, I know the loading is 1120 KG but that does not help.
Has anybody found pressure for this tyre? and what does the "Q" on the end mean?
Doug...
icantremember
8,334
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Q rated tyres are for max speed of 99 MPH
I have the Michelin Agilis on my m/h and they are certainly good for 80psi I run my rears.
Just checked .......mine are 225/75 R16 so will be different to yours
aba
2,775
1,112
yorkshire
dec 2009
i would think its somewhere similar to the XC camping tyre as they are the replacement.
try the michelin website they should have the info required.
they also have M&S ratings if they have over a certain amount of tread so they are a better option if travelling abroad in winter.
aba
2,775
1,112
yorkshire
dec 2009
it says on the michelin website front 4.5 Bars rear 5.5 Bars
but need metallic valves for these pressures:thumb:
Douglas
Douglas
2,835
400
South Wales,
Your not going to believe this.... but I have just spent the last hour searching the Michelin site for "pressures" and found none, other that to look on the door pillar!!!
Can you give my the ULR for that page please.
Doug...
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
80 psi seems a lot, What weight is the van ?.
aba
2,775
1,112
yorkshire
dec 2009
i dont think its to do with the weight of the van in reality.
i think its more to stop the flat spots occurring whilst stood.
although mine are at around 80psi but on a 5 ton tag so each tyre actually sees well under a ton
icantremember
8,334
17,545
Hymer T-SL668
since 2005
I got the tyre pressures for mine by calling Michelin customer services with details of fully laden axle weights (from local weighbridge) and tyres.
They came back with the recommended pressures and allowable variations for comfort.
Customer Service Centre for UK and Ireland
Campbell Road
Stoke-on-Trent
ST4 4EY
Tel:0800 591 859
e-mail: south-court.reception@uk.michelin.com
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
I can recommend Michelin at Stoke, there technical dept is very good. Have had several dealings with them in the past and can only praise them. If Michelin told you to put 80 psi in it must be right. It just seemed a lot to me. I run 3500kgs with 60psi front and 65psi rear. Will ring the Mich on Monday as I could well be under inflated.
Jul 28, 2010
1,710
617
The world
Small car
if you ask
P. & B. TYRES (OSWESTRY) LTD
Brian is on the RVOC site i am sure he will know the right info for your tyre
sorry i do not have his phone number to hand
icantremember
8,334
17,545
Hymer T-SL668
since 2005
You will need your fully loaded axle weights for accurate results
