- Jan 11, 2023
- 7
- 0
- Renault Master 2006
Hi all, first time here, hoping someone can help us understand what's gone wrong with our leisure battery system.
Today our inverter started beeping to say the battery power was too low. We turned it off and then found that the positive battery terminal on one of our 12v leisure batteries has melted.
We have 3x 12v batteries, wired in parallel, connected to our inverter which only runs an electric water heater every so often (3 times in the last month).
The cable us is 35mm.
It's the last battery in the circuit that's had the issue. The one connected to the inverter.
The positive cable from the battery to the inverter was very hot also.
Our power comes via split charge and solar.
We disconnected and removed the battery now. And will not connect the inverter again.
Just wondering whats gone on here, in case it's something that might happen again?
Any helpful thoughts/suggestions appreciated.
