Maxview Crank Up (1 Viewer)
micky drip
191
121
mid wales
c class
5 years
I suspect that the co-ax feed from the LNB is damaged inside the crank/rotating mechanism of my wind up dish.
Any of you Funsters got any suggestions on how to repair said cable ?
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Can you use the existing cable to pull through a new length of cable? I have the same dish on my MH but it's in storage so I can't check the fine detail.
2,396
10,472
I had one on my RV.. and unless they have changed the design, the LNB cable doesn't go thought the crank mechanism, it is routed through a gland in the roof.. as you can see in this photo ..
micky drip
micky drip
191
121
mid wales
c class
5 years
seems like a good idea, will try, but there must be a coil inside to allow dish to rotate?
2,396
10,472
can't remember exactly how the cable is routed internally, that photo was 2007.. and the RV is long since sold.. , but don't think there is a coil or anything fancy inside .. probably just a bit of slack cable to allow turning back and forth, .. only way to find out is to have a look see ...
magicsurfbus
4,673
10,127
NW England
Since 1997
The dish can't rotate endlessly - it stops at a certain point then has to go back the other way. That would suggest the linkage may be uncomplicated, like a cable. Don't the installation instructions have an exploded diagram?
micky drip
micky drip
191
121
mid wales
c class
5 years
Have not found installation guide yet, also I am unable to get on roof, can`t reach far side of dish mounting. Were is BOATER?
2,396
10,472
The most likely problem is a bad connection at the LNB .. wet and or broken.. but you will need to find a way onto the roof .. no other way.
artona
1,511
817
self build
40 yrs and still not got a release date
micky drip
micky drip
191
121
mid wales
c class
5 years
Thanks for the link to maxview.
Unfortunately I can`t open it just get Gobbledee gook, any ideas?
2,396
10,472
it works ok for me Micky.. but it is just the installation instructions.. doesn't show an exploded view ..
have you got on the roof yet ?
micky drip
micky drip
191
121
mid wales
c class
5 years
too fat to get thru roof window, waiting till pembrey rock for santas helper
Thanks to u all. Will let u know the outcome
micky drip
micky drip
191
121
mid wales
c class
5 years
Thanks to you all for your input on my Maaxview problem. My brother in law managed to reach from roof window fitted new LNB and remade F plug... Job Jobbed
