Maximum Technical Permissible Mass.
Basically same as GVW.
So an easy 8000KG GTW (gross train weight or GCW gross combined wight)
seen one at 44K
AlKO chassis is unpainted galvanised steel from the rear of the cab... fiat chassis cab is painted steel throughout.
ALKO chassis is fitted by the converter, not Fiat.
The cab is supplied without a chassis from the cab backwards or the fiat chassis is removed and replaced with an ALKO by the converter.
This is how they are transported/delivered.
seen one at 44K
Yep, the weight plate law was introduced to discourage home builders.
Unless you have an engineering understanding/background you will have no idea of the structural strength of a trailer or its static and dynamic weight bearing ability...professional builders do know so can safely issue a given weight plate accordingly.
Agree, but most will issue a new plate if DOWNrating a heavier trailwrIn my experience most of the big name trailer builders have homologated a range of trailers and will not deviate from them even if you offer to get an individual cert on it.. I managed it eventually by phoning one who after a bit of a chat realised that I knew a bit of what I was talking about, I needed a 7 metre bed (legal limit unless indivisable load) but did not need 7'6" or 8' width. As I didnt need weight capacity we settled on 5'10" wide and 7 metre bed and 2 x 1300KG axles as the steel sections, being slightly bigger, would help with twist.
I stand corrected on the VIN. However what happens if I build my own?
And as far as I'm aware a trailer can still be downplated by the owner simply by re-stamping the plate.
Our van is 6000kg MAM or GVW or whatever, so for sure this gives at least 2250kg for a trailer, the van would still be very useable downplayed to 5500kg to allow a trailer of 2750kg to stay within 8250 GTW or GCW, wether that is the way to do it or not I am not 100% sure but it looks that way to me.
Sorry can't help with that.either way would suit me, price of MH may be a touch out of my range tho
They obviously know the strength is unaffected unlike updating.
You can get vans on the IVECO 50C 5000kg or 60C 6000kg chassis for less money as N+B are not the cheapest, if you want to tow post 2005 gives the option of the 3 litre which has a lot more grunt than the previous 2.8.
If that is true it hardly discourages anyone really. I've built 4 over a number of years - two based on early caravan chassis, one on a Mini subframe, and one on Indespension units. All had a weight plate (or stamp really) based on the suspension l was using at the time.Yep, the weight plate law was introduced to discourage home builders.
Thats tidy.
Our 3,500kg Iveco PVC has a GTW of 7000kg. but crap brakes.Iveco Vans also have a very good towing limit often 3500KG as they are both heavy and powerful, what is MTPM excuse my ignorance,
Yes lots of 3 litre Fiat based MH's are using the IVECO block but FWD in my book you need to stick with the IVECO badge on the front to get RWD and the best payload and towing capacity.Thanks Martin, I have noticed a lot of the other MH's are now fitting the 3.0 engine which I think is the Iveco unit.. I'd like a N+B but also quite like the dethleffs and burstner ranges.
Mine was the same I'm sure the adition of a well braked trailer could only improve the brakingDucato Maxi chassis like mine came plated at 6500kG GTM giving it 3000KG towing capacity if the van weight is at 3500kg
In that case if l build another it will finished in 2011.If you build a trailer now after 2012 it has to be EU type approved which means it has to be submitted to be IVA tested it meets the regulations .
Manufacturers can't downplate a trailer unless they have submitted the trailer for type approval at the different weights .
Vin plates on trailers after 2012 are a lot more regulated like motor vehicles plates. Prior since 82 a trailer only required a plate with the trailers MAM .
If a trailer has not got a plate then the axle plate or tyre load index number on the tyres would be used if stopped by authorities .
Tell that to Ifor Williams.....they obviously haven't been told.Manufacturers can't downplate a trailer unless they have submitted the trailer for type approval at the different weights .
Not since 1982 there shouldn't be.But there are lots of trailers out there without plates how do they overcome that?
Required since 1982, If no plate tyre limit is taken as max weight x number & trailer will be taken & weighed , as above.I don’t think you have to have a trailer plated so no offence? My observations are that with the type approval of Towbars and also new trailers that may be an offence on newer trailers but older ones have nothing on.
As far as I know the law says if no weight plate is present on the trailer the max weight is taken to be the combined loading stated on the tyre side wall as singles x number of tyres, because even if the trailer is plated higher, it still can only take the maximum the tyres can handle, and are rated at
You can't since 29th Oct.2012 without sva testing to homologate & get a plate.unless you do as you say & build it prior to that
■Since 1982 all trailers, including unbraked ones, must be clearly marked with their maximum gross weight in kilogrammes.
■Since January 1, 1997, all unbraked trailer plates must show the year of manufacture.
■Department of Transport Code of Practice states that is desirable for trailers less than 3,500kg gross vehicle to carry a manufacturer's plate clearly showing manufacturer's name and address, chassis or serial number, model number, number of axles, maximum weight per axle, nose weight or coupling, maximum gross weight and date of manufacturer.
If you built it yourself prior to the 2012 date it should still have complied with the above.
How long will it take for the UK to adopt the Northern Ireland requirement for testing of all trailers?
If it's a chassis cab base then I'm surprised that you can tow so little.
I don't see that as being right, the towing weight will have been decided by Alko who know what their chassis will take, you can't simply increase that because the van is lighter.That would be your towing weight limit only if your actual MH weight is 3500Kg.
If you run at, for example, 3000Kg, the you would be able to tow 1330Kg.
Ian
Converters plate will supercede the Fiat one.The weights quoted in my posts were the stickers on both front seats, today I looked at the chassis plate that fiat fittedand its a different story
GVW 3500KG
CVW 5500KG
so according to FIAT a 2000KG is acceptable? I could downplate the trailer to 2000KG and actually carry a lot of things on the trailer instead of inside the motorhome.
I'm going to take it to a weighbridge and see how much it weighs, fuel tank is nearly full, water tanks are about 30% full, full of pots and pans, food, clothing, awning and privacy room and other bits and bobs.
should I use the manufacturers weights or the converters?
