Lubricants (2 Viewers)
Sep 26, 2019
278
395
AutoSleeper Broadway
I had a problem for a while with my electric step, into the rear habitation door, as it used to seize up from time to time. However I took my motorhome to a new place for its habitation check. I was very impressed as they included taking out some scratches on the body work and lubricating the mechanism of the step. The step has now worked excellent for 18 month. I could see that the lubricant they used was like a white fine grease, much better than my WD40!
Does anybody know what type of lubricant this might be and where to get it. The step is still OK, but I'm thinking this white stuff could be good for locks and hinges etc.
Apr 9, 2018
8,643
44,628
Worcestershire
Bailey Adamo 75-4t
March 2018
Sounds like a lithium grease.
Aug 4, 2019
1,923
8,510
North East Riviera
Low profile
Enough to Survive
I can’t help with what they might have used, but I wouldn’t use WD40 as a lubricant.
Standard WD40 has good water displacement and seize release properties but as a lubricant it‘s not good and dries out pretty quickly.
I‘d probably use a bog standard grease or as mentioned a silicone based one.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
WD40 is not a lubricant. It is far more likely to strip any remaining lubricant away and make thing worse. White lithium grease spray is probably what you saw and is readily available. You can even get it in a WD-40 branded can if you want!
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
I use silicon spray for all friction points inside and out.
Very good for bike chains sprockets etc whilst they hang on the back of the van.
Also does all plastics, window seals the list is endless and it lasts for ages.
Mitch.
Davecrawf
Sep 26, 2019
278
395
Thanks for all the advice everyone.
53,449
150,081
You were luck, the step has nylon and WD40 makes nylon swell. Also if there are any plastic bearing surfaces you shouldn't use white lithium grease it causes surfaces to bind.
I had a problem with my drivers door step, it kept juddering. It's a straight slide out step. The dealer sorted it under warranty but a couple of months later it was juddering again the idiots had use white lithium grease on it. I stripped it down myself cleaned all the grease off it reassembled it using standard grease (Castrol LM) over 2 years later it's still working perfectly.
On the hab step that pivots down I use silicon spray.
Dec 23, 2014
2,178
2,820
South Somerset
Carthago C-Line I 50
Time and again people have said to me try WD40 and my reply is normally "which one?" there are so many. It is well worth looking at their website and choosing the right product for the job you have in hand.
WD-40 Products
23,836
72,498
WD-40 do a spray can motorbike chain wax that contains PTFE, this is white and may have been used.
DO NOT GO NEAR THE BLOODY STUFF !!!
We had a few early failures of chains, all DID good quality stuff..
Turned out the common factor was WD40 chain lube !!!!
Sep 16, 2010
3,010
2,858
Bungay Suffolk
In my opinion, grease of any sort will get stuck up with dust and become a very nasty abrasive.
Again, use silicon spray !
Mitch.
