LPG on demand wster heaters.
Joben
Leicester, UK
Van Conversion
New to it. Converting a Renault Master... slowly!!
I've installed a LPG tank and will be fitting a gas hob for cooking. I have seen some water heaters advertised (Camplux/Cointra etc) but they tend to be portable ones. Ideally I want to fit one permanently with an air intake (easy enough to sort out) and a 90° flue that will exit through the side of the van. Is the such a beast out there or, if not, is there a manufacturer that could make one?
Thanks in advance,
John
I have a Camplux heater in my garage for use as an outside shower. I think you can fit a different flue. Works very well - heats instantly.
Thanks Ninjabob. It's the instant hot water I'm after. Will look into flues.
Those are not intended for use inside a vehicle far safer to fit a proper balance flue gas heater.
Instant LPG heaters are common in the USA. Unfortunately, they generally match the dimensions and cutout requirements of the large 6-10 gallon water heaters that are common there. If you can cope with the large cutout, they're readily available.
