- Jul 6, 2009
- 2,239
- 2,827
Hi all, we have had the following fitted *4 x 175 watt solar panels, Victron mttp 60 amp controller • Victron 2Kva Multi • Victron GX touch control panel • 230 amp upgraded split charge • Victron battery protects for the charge and loads • Victron Cerbo control system • Victron BMV battery shunt • 2 x Transporter Energy batteries We are fortunate to have a large garage at the bottom of our garden to keep the van in. There lies a small problem. As it is in the garage no solar benefit. I have fitted the original 100 watt panel that came with the van on the roof of the garage and fed it via the buzz bar into the van. Obviously at this time of year it does not keep up with the 0.7 amp hour draw this system uses to power the mifi, monitoring,tracker and the parasitic current draw. Would you keep the van permanently on hook up and let the Victron float charge the batteries? Or let it rundown to say 60% soc and then bring it back up to 80% as I understand it is best to not keep these batteries fully charged if you are not using the van. |
