Leisure battery
Hymer b544 classic
Newbies
Hi to everyone, hope someone can shed some light on the problem I now seem to have. We went to Southport last week and everything was fine with the batteries, when we got home and unpacked we stupidly lefted the 12v on and a light on. Next morning the leisure battery was completely flat. I thought no worries I'll just give it a 24 hour re- charge and it will be fine. But now no matter what we do the battery will not hold it's charge! Is it as I suspect a now knackered leisure battery??.
The van is a 2001 Hymer Bclass, we bought it in February! Great time to buy eh!!! Not sure of the history of wild camping. The battery is a A28 varta 12v 110ah (20h) 90ah (5h) if that's any good? I have it plugged in now to charge overnight and try again.
Sounds like the battery has had it. Don't leave it on charge trying to charge a dead battery is one of the best ways of blowing up an Elektroblock.
The original battery would had been a Gel worth checking the Ekektroblock is on the correct setting as if set to Gel it will have shortened the life of your battery.
What's an electronic?
Electroblok
Often under the passenger seat
sometimes, and I do mean sometimes you can recover a battery from dead flat by using jump leads and another battery to trick the battery charger into charging. Some chargers will not start charging if they don't see a high enough voltage on the battery. However, deeply discharging a battery will damage it and ultimately kill it
